Author Topic: Details of a 68 RS Z/28  (Read 125534 times)
169INDY
Re: Details of a 68 RS Z/28
« Reply #45 on: August 31, 2016, 12:50:32 AM »
Thank you thank you!
Wow. Looking at the R/S tank & Associated Check valve (External; per the UPC 12 EN dated _Jan 5th 1968_) & filter, I was able to better understand the proper Config MY car should be set as (The Car was front ended in 1979 by previous owner) and they omitted the filter but kept the ORIG external check valve. So I was able to come to terms with this detail. I had a NOS (AC marked) filter in the drawer from Old Classic Camaro orders back in the 80's. Chick sincerely thanks for taking the time to post the pic's
As a side note Both my LOS cars (68/69) have the 1" washers on the hinges, Could it be a Plant -vs- Plant thing?
JIM Weaver
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
« Reply #46 on: August 31, 2016, 01:06:04 AM »
JIM Weaver
Thanks Jim for both the kind words and the info from your LOS cars. We or I have viewed very few LOS cars and when I have never looked at the hinge to fender arrangement. Might just be a plant thing as suggested.
Trunk W/S-
Trunk hinge to lid screw-
Spoiler screw has green paint on end.
Paint Stripe Details-
20Z28/100_6210_zpsd7wmciyp.jpg.html][/URL]
20Z28/100_6209_zpsdij6saeo.jpg.html][/URL]
« Reply #47 on: August 31, 2016, 01:11:32 AM »
More 68 Z/28 paint stripe details-
« Reply #48 on: September 02, 2016, 10:53:29 PM »
I don't know how consistent this would apply however I have seen quite a few original paint LOS cars with the wiper cowl stripe confined to the recess whereas many of the NOR cars have the stripe 1/4-3/8 outside the on the aft portion.
« Reply #49 on: September 03, 2016, 02:33:08 PM »
Great car and time capsule.
« Reply #50 on: September 03, 2016, 06:04:45 PM »
Darrell, are your photos from a LOS or NOR car?
« Reply #51 on: September 03, 2016, 06:10:27 PM »
LOS
« Reply #52 on: January 10, 2017, 02:06:06 AM »
Original born with battery tray. Note the tab where the battery hold down clamp bolts on. Will not find that tab on NOS service replacement battery trays.
« Reply #53 on: January 11, 2017, 07:23:49 PM »
I would be interested to know whether the batt tray was similar to the mid 70's X bodies (Nova) as I beleive it would probably fit.
lilfighta
« Reply #54 on: January 18, 2017, 04:50:37 PM »
hello 68camaroz28 can you tell me if the front wheel well moldings got to the bottom on the rear wheel well and same with the rear wheel well mouldings do they go to the bottom of wheel well  or cut off by body lower side moulding
thank you mike
dutch
  • Documented Canadian 1968 Z/28
« Reply #55 on: January 18, 2017, 05:21:47 PM »
Chick - did you happen to take any pictures of the water pump bypass hose fitting on this car. I assume it also is the hexagon style - but none of pictures actually showed much engine details and I was wondering..
Thanks - Randy
« Reply #56 on: January 18, 2017, 06:46:47 PM »
thank you mike
Mike, the car has RS wheel moldings which stop at the body lower side molding.
« Reply #57 on: January 18, 2017, 07:03:36 PM »
Thanks - Randy
Randy, look at post #19 as there's a picture that might help with your question but let me know if not.
dutch
« Reply #58 on: January 19, 2017, 04:13:41 AM »
Oops - sorry Chick I did look at that picture too - but obviously not close enough to see what I needed and was asking for... eyes are getting old I guess!
Thx - Randy
« Reply #59 on: January 20, 2017, 04:08:40 AM »
Thx - Randy
Here you go Randy as picture of hex design can be more clearly noted. Note the paint as I'm convinced the by-pass hose and nozzle were installed on the engine at Flint and painted.
