Main Menu
What are these parts in the trunk ?
Started by Martin D, May 18, 2025, 12:40:28 PM
Previous topic - Next topic
Martin D
What are these parts on a 69 convertible ?
1 each in the trunk rear corners & one in the rh front fender
Martin D
And this from the front
boomer632
Commonly referred to as cocktail shakers. Only found in convertible cars.
06A X66 711 57 57 M22 BU
Martin D
Quote from: boomer632 on May 18, 2025, 01:38:27 PM
I can see why with some sort of oil in them, they are not connected to anything, some sort of anti vibration thing?
KevinW
Yes, filled with ATF and has a drilled cyl between springs to help with cowl shake on verts.  You need them, keep them and restore with car. Very expensive to replace as they are not reproduced and they are unique to car and year.
Martin D
Quote from: KevinW on May 18, 2025, 03:03:42 PM
Thank you 👍
Charley PHX
Quote from: Martin D on May 18, 2025, 12:40:28 PM
Should be four. One in each corner. Best of luck finding #4! They do still turn up once in a while (but scarce)
'67 04D (LOS) L-35/M20 (-L181A) Convertible (owned since 1975) - Bow Tie 981/1000 GOLD (July 2023)
'67 06D (LOS) L-78 Coupe (body) (1979 barn find) - Gone but not forgotten!
Quote from: Charley PHX on May 31, 2025, 10:46:12 PM
There are six different listings on Marketplace now for cocktail shakers. And that's just in new england.
