Author Topic: Original 10 bolt oil type  (Read 21486 times)
Daniel Cate
« on: March 27, 2006, 03:32:13 AM »
What is the correct weight of rear end gear oil for an original 1968 10 bolt rear? Also how much in quantity? I haven't taken the time to dig through my assembly manual. I'm sure the info's in there if someone has a page reference I'll dig it out. Thanks, Dan
Re: Original 10 bolt oil type
« Reply #1 on: March 27, 2006, 03:29:08 PM »
Dan,
90wt Hypoid Gear Oil is the original lube for the rear end and the manual transmissions. If you have Posi, you also need to add the posi lube.
There's a plug on the side that you fill it from, and when it starts leaking out, it's full. As for exact quantity, I "believe" it's a few quarts, but I'm not close to my service manual right now to verify that. I'm sure someone else can...
« Reply #2 on: March 27, 2006, 03:55:56 PM »
10-bolt is 3-1/2 pints, 12-bolt is 4-1/2 pints.  :)
Daniel Cate
« Reply #3 on: March 27, 2006, 05:19:20 PM »
Thanks guys,
That's what I was looking for. Dan
« Reply #4 on: March 27, 2006, 10:32:29 PM »
Quote
Hey! I was only off by a few pints!! (That should make a nice mess on the garage floor...)
 :o
