Author Topic: 19N509257 DZ 302 Block on ebay  (Read 14182 times)
Crownstables
« on: February 17, 2018, 09:11:47 PM »
V1I07DZ
Dated October 31st, 1968
Seller - michaelsclassicandmusclecarparts
Ebay ad title - 1969 Camaro Z28 DZ 302 3932386 Block J-31-8 STD
Gramps69Z
  • 69 X33 D80
Captain John Wykoff
Crownstables
Re: 19N509257 DZ 302 Block on ebay
« Reply #2 on: February 17, 2018, 11:54:32 PM »
Thanks Gramps69Z - much easier.
« Reply #3 on: February 18, 2018, 07:56:27 PM »
Looks real, but unless they found a way to time travel, wasn't originally installed in N509257. Probably meant L509257.
Crownstables
« Reply #4 on: February 19, 2018, 12:43:43 AM »
"william" - could you educate me and elaborate on your reply.  Thank you
« Reply #5 on: February 19, 2018, 02:23:23 AM »
The block was completed on 7 November 68.   L509257 was completed in LA during late November '68, whereas N509257 was completed in Norwood during late September.
Seems this engine could not have come in a Norwood car, but *might* have come in an LA car...
Gary
« Reply #6 on: February 19, 2018, 02:28:36 AM »
It’s in CA so makes sense that it would be from a LOS car.
« Reply #7 on: February 19, 2018, 02:37:09 AM »
Sure.
There were two US 1st Gen Camaro assembly plants: Norwood, Ohio and Van Nuys, CA. The Norwood plant initially only built Camaros; Firebird moved there April of '69. For 1969 Norwood produced about 87% of total Camaro production. The Van Nuys plant built several other cars in addition to Camaro.
At both plants, Camaro VIN sequencing started at 500001. Norwood Camaros had an N VIN prefix, Van Nuys Camaros had an L VIN prefix. From many decades of data gathering, reverse-engineered production calendars have been compiled. From these it is possible to estimate a production date given a VIN. Cars were not built in exact VIN order.
V1107DZ is a 302 engine final-assembled at the Flint, MI plant on November 7, 1968.
Camaro N509257 was final-assembled at Norwood on or about September 24, 1968. It could not possibly have had an engine built November 7, 1968.
Camaro L509257 was final-assembled at Van Nuys on or about November 19, 1968. It could have had an engine built November 7, 1968.
Crownstables
« Reply #8 on: February 19, 2018, 01:38:29 PM »
Thank you for your replies and knowledge, I learn so much from this site. The ebay seller must be getting that partial VIN off the rough part of the block by the oil filter. He shows a picture of that area but I cannot see anything.
HOT3O2
« Reply #9 on: February 19, 2018, 03:13:53 PM »
William, Wouldn't a LA block of that time frame have the VIN stamped on the pad?
Rick
69 RS/Z28
« Reply #10 on: February 19, 2018, 03:29:09 PM »
I'm surprised not to see a VIN from either plant on the pad. They were somewhat inconsistent; years ago I had a late October '68 302 stamped by the oil filter.
HOT3O2
« Reply #11 on: February 19, 2018, 05:52:10 PM »
I guess it was up to who ever was doing the stamping at the time. A lot of good info. Thanks
Rick
69 RS/Z28
« Reply #12 on: February 20, 2018, 05:01:09 AM »
You would think they would have had a process for stamping it on the side vs. the top. I am still surprised that there is such a large window of inconstancy with Vin location. What is the earliest vin stamped by the oil filter? what is the latest known vin stamped on the pad? (LA and Norwood examples if you have them)
X33RS
« Reply #13 on: February 20, 2018, 03:58:31 PM »
Mine is stamped at the oil filter and is a 12D built Norwood car, engine stamped 12-27 I think (have to look again).  I've looked at 2 other Norwood blocks for sale in recent past that were stamped mid Dec 68 builds and they both also had the vin at the oil filter just a week or two before mine.
I had info on a Norwood built DZ engine with a build date stamp late November here somewhere, and it had the vin at the oil filter also.  I'll have to dig and see if I can find it.   That's the earliest I've ever seen a Norwood car done that way.
I was under the impression that Van Nuys was stamping vins at the oil filter earlier then Norwood was.
« Reply #14 on: February 20, 2018, 04:42:36 PM »
Some late-March built ZL1s are VIN stamped on the pad.
