Author Topic: carburetor date  (Read 24867 times)
lilfighta
carburetor date
« on: February 13, 2017, 10:20:32 PM »
Hello could someone tell me how many months prior to a car being built is the carb date. For example if car was
built in june 1968 would a February or March be correct. Also what carb came on car rochester or carter. Or you need the build sheet
thx mike
Re: carburetor date
« Reply #1 on: February 13, 2017, 11:05:31 PM »
thx mike
Mike, Carter carburetors were not available on Camaros in 1968...
http://www.camaros.org/carb.shtml#usage
lilfighta
Re: carburetor date
« Reply #2 on: February 13, 2017, 11:47:02 PM »
Paul I believe they were. Im mostly interested in date factor. The time factor
thx
Re: carburetor date
« Reply #3 on: February 14, 2017, 12:34:00 AM »
AMAZING!
lilfighta
Re: carburetor date
« Reply #4 on: February 14, 2017, 01:12:08 AM »
Why do you say amazing? Because i said they were available ?
Re: carburetor date
« Reply #5 on: February 14, 2017, 01:48:10 AM »
Not from the factory.
x66 714
Re: carburetor date
« Reply #6 on: February 14, 2017, 01:53:45 AM »
I thought Carter was building Q-jets for a while or am I mistaken?...Joe
lilfighta
Re: carburetor date
« Reply #7 on: February 14, 2017, 02:02:40 AM »
The story was when rochester couldnt supply enough to gm carter was building them and they did build them for awhile and if i remember they started in 1965 - 1970 i think dont hold me to the exact dates. Does anyone know about the date codes for june 1968 camaro
carburetor
thx
Re: carburetor date
« Reply #8 on: February 14, 2017, 04:10:50 AM »
Carter built Quadrajets were built and used for many years - including 67-9.
>However, Carter was also licensed to build the Quadrajet as a secondary source, and supplied carburetors to not only Chevrolet, but other GM divisions as well.
June car probably had a May or June carb on it (depending on when in June).
Re: carburetor date
« Reply #9 on: February 14, 2017, 06:04:52 AM »
 Both of my '67 L35's (04B & 05B) have their original Carter made Quadrajets.
Re: carburetor date
« Reply #10 on: February 14, 2017, 07:49:21 AM »
Carb for June car, yes most likely dated in May. Early June carb possible if car is a late June build.
lilfighta
Re: carburetor date
« Reply #11 on: February 14, 2017, 03:48:17 PM »
Thank you KurtS and Mike. A friend told me that it is possible that you can use a carb built
in March or April also. He said you can go back as far as 2-3 months just trying to clarify this.
THx
lilfighta
Re: carburetor date
« Reply #12 on: February 14, 2017, 03:53:03 PM »
Kurt S carter used the carbs on alot of chryslers also same years.
lilfighta
Re: carburetor date
« Reply #13 on: February 14, 2017, 03:57:25 PM »
LOL I forget where does it tell your car has a carter or rochester. Is it on the POP or on the build sheet
Alot of questions from 1 guy eh kurt LOL
Re: carburetor date
« Reply #14 on: February 14, 2017, 06:01:04 PM »
THx
My thinking the date depends in part of the engine popularity so I'm sure the carb date would vary.
