Author Topic: Hurst Shifter date codes  (Read 173047 times)
69 Zee
Re: Hurst Shifter date codes
« Reply #15 on: April 10, 2016, 01:44:38 AM »
Build date:  03B
Shifter code:  19D52P
Darrell
'69 Camaro Z/28: 03B NOR X77 Dusk Blue, white top, all orig, Under construction
'70 Plymouth Superbird: One owner, Limelight green, 45K miles, all original U code
« Reply #16 on: April 10, 2016, 01:55:54 AM »
Thanks Darrell!
suturb110
« Reply #17 on: April 10, 2016, 05:20:23 PM »
Early Van Nuys 1969 Camaro Z28
Build Date 09D  (1968)
Shifter Date code  8 8D3
Original Shifter for car
« Reply #18 on: April 10, 2016, 05:30:53 PM »
suturb110 - thanks for your data.  Would you happen to have a pic of the date code?
I think we are starting to see a pattern that some early 69s used the 4 digit date code.  Now hopefully more data will give us the approximate time of the change.
69 Zee
« Reply #19 on: April 10, 2016, 06:07:58 PM »
Please note that mine is a Norwood production if needed.
Darrell
« Reply #20 on: April 11, 2016, 02:16:21 AM »
Steve (paceme),
Does your Firebird have its original shifter? What's the code?
suturb110
« Reply #21 on: April 11, 2016, 04:48:53 AM »
Hi,
Attached is a picture of my early 1969 Z28 shifter. Build  code 09D 1968 Van Nuys.  The shifter date code is 8 8 D3. The first "8" was stamped real lightly by the bolt.  The rest of the date code is real clear. After I resized the picture the first "8" got more faint.
« Reply #22 on: April 11, 2016, 06:24:19 AM »
Date         shifter
09C NOR   890731C
09D LOS   88D3
12B NOR  68B2
03B NOR  19D52P
07A NOR  690711F
« Reply #23 on: April 11, 2016, 03:40:15 PM »
Minor change to order. Gary has a late car (09C)
Date         shifter
09D LOS   88D3
12B NOR  68B2
03B NOR  19D52P
07A NOR  690711F
09C NOR   890731C
X33RS
« Reply #24 on: April 11, 2016, 08:02:13 PM »
I thought I remembered doing this before??
Car
12D 69 Z Norwood
Shifter
1280D31D
« Reply #25 on: April 11, 2016, 09:41:45 PM »
You may have submitted it before, and we missed it. Sorry about that. We will add it. :)
Data on EARLY cars is the most important for what we are trying to determine.
67pacer
« Reply #26 on: April 11, 2016, 10:38:25 PM »
Date           Shifter
02C LOS    19D52M
Bill
Bill
X33RS
« Reply #27 on: April 12, 2016, 01:00:37 PM »
No apology needed Bryon.  I was just making sure I wasn't losing my mind, lol.
cruizin69
« Reply #28 on: April 12, 2016, 01:29:42 PM »
The date Code on my shifter is 19D51J from a 02A Z/28
« Reply #29 on: April 12, 2016, 01:50:32 PM »
Car           shifter date
09D LOS   88D3
12B NOR  68B2
12D NOR 1280D31D
02A xxx  19D51J
02C LOS  19D52M
03B NOR  19D52P
07A NOR  690711F
09C NOR   890731C
« Last Edit: April 13, 2016, 04:06:21 PM by bcmiller »
