Camaro Research Group Discussion => Research Topics & Reports => Topic started by: JoeC on April 06, 2016, 08:10:12 PM
Title: Hurst Shifter date codes
Post by: JoeC on April 06, 2016, 08:10:12 PM
I was the one who said the 4 digit code was a Firebird shifter.
From what I have seen , the 4 digit code was used on the early OEM Hurst shifters 1964 to 1968/69
All the  1969 Camaro shifters I have seen have the 6 or 7 digit code but it could be that some 4 digit coded shifters were used on Camaros.
I didn't keep track of the 4 digit codes but have a bunch or codes from actual 1969 Camaros .
here are some including the earliest one I have and the latest one I have and some in-between.
The earliest one I can find is Oct 1968 so I don't know when they changed to the  6 or 7 digit code.
Would need more data to find the latest 4 digit code and earliest  6 or 7 digit code
108D41C
118B18H
118D22M
128D33P
19D53D
29D21C
39D11D
59D72K
99B35D
Title: Re: Hurst Shifter date codes
Post by: bcmiller on April 06, 2016, 08:54:14 PM
Joe I cut your post above from that other thread and started this topic.
You may be onto something. I will check to see what else I have for Pontiac Hurst shifters later this evening. A quick look at a 68 GTO shifter shows the similar 4 digit code (but coded for Feb 68) as that Firebird shifter.
OK I checked. The two images below are not from Camaros, but are related to the date coding.
68 GTO Hurst 4 speed shifter dated Feb 68 and 66 Lemans Hurst 3 speed shifter dated September 65.
Post by: ko-lek-tor on April 06, 2016, 10:16:21 PM
In addition to the 68B2 I posted a pic of in the other post...I also have a 19D33D & 39D21(Q or O?)
Post by: bcmiller on April 06, 2016, 11:45:29 PM
Do you have dates of the cars those shifters are from?
Your other shifter dated 6 8B2 was in your 12B car.
The one posted a bit earlier was 6 8B2 from a 10B car.
Post by: ko-lek-tor on April 06, 2016, 11:49:39 PM
I remember both cars the shifters came out of, but back then we never looked at dates. So, sorry I cannot provide much.
Added pics. last pic 68B2 is off 12B Nor. X22
Post by: KurtS on April 07, 2016, 01:10:28 AM
Thanks for starting this thread. I was just about to. :)
If 69 owners could post their shifter dates and also their car's build date, we'll tabulate and see what the data says....
Post by: 69Z28-RS on April 07, 2016, 01:18:59 AM
I think I've done this before when we were discussing shifter dates, but here it is again:
69Z28-RS     09C (18Sept1969)      Shifter mfg code      890731C    (Aug'69? mfg 31Jul?)
Post by: bcmiller on April 07, 2016, 01:28:17 AM
Gary, Joe may have a better idea. I know I have checked around in the past to try to find answers.
All I am PRETTY SURE of is the month and year. I THINK the numbers and letters after that are the batch code - but I don't know the exact decode for that part. Or if there even is a decode for the batch number.
Thus the reason for this thread and requesting data.
Post by: 69Z28-RS on April 07, 2016, 01:44:12 AM
Could be...  the 0731 was so close to the Aug 69...  I thought it *might* be?  ie. maybe a daily batch?
Note:  PaceMe (Steve Shauger) has a good understanding of these codes, as it was info from him that provided the info on month/yr/etc...
Here's another one.  This was a swap meet shifter I picked up long ago, and traded to Dave Hawksley (maybe he's cleaned it and has a better photo of the mfg code)... :)
Looks to me like:    590423D
Post by: bcmiller on April 07, 2016, 01:53:42 AM
Not likely a date since you note in the first post several with numbers in the batch code above 31 (max number of days in any month).
The month/year code info is pretty widely known.
Post by: HawkX66 on April 07, 2016, 12:10:19 PM
I got this shifter from Gary (69Z28-RS). It came from a Camaro, but I can't confirm the build dates of the car.
190423D (Jan 69)
(http://i1164.photobucket.com/albums/q573/SgtHawkUSMC/69%20Camaro%20SS396%20L34/69%20Trans%20M21%20Muncie/69%20Shifter/IMAG0688.jpg) (http://s1164.photobucket.com/user/SgtHawkUSMC/media/69%20Camaro%20SS396%20L34/69%20Trans%20M21%20Muncie/69%20Shifter/IMAG0688.jpg.html)
Post by: JoeC on April 07, 2016, 11:45:00 PM
I have 3 shifters at home I forgot to ad to my notes
78D2
19D53D (same number as one in my notes but different shifter)
690511C
I thought the 78D2 was a Firebird shifter but now that I think about it, a July shifter seems late for a 1968 car build
Hard to say what Hurst was doing with the codes/numbers
with the 6-7 digit codes, some have one letter some have two
a lot of "Ds" seem to show up
I know that approximately in the early 70s  , Hurst changed the numbers used on the aftermarket shifters.
They went from using a serial number to using an ID code such as 391- 4340
Post by: bcmiller on April 08, 2016, 07:40:09 PM
Thanks Joe.
We are still looking for Hurst shifter dates from original cars. Everyone - Please post if you have data.  Especially from early 69s. Thanks!
Post by: Jon Mello on April 09, 2016, 01:55:39 AM
690711F code from 19N667739, P9H20B
(http://i586.photobucket.com/albums/ss309/1967z28/January%202014/69%20Hurst%20shifter%20numbers%2019N667739%20P9H20B_zpsddo22i5e.jpg) (http://s586.photobucket.com/user/1967z28/media/January%202014/69%20Hurst%20shifter%20numbers%2019N667739%20P9H20B_zpsddo22i5e.jpg.html)
Post by: bcmiller on April 09, 2016, 12:10:20 PM
Thank you Jon!
Post by: 69 Zee on April 10, 2016, 01:44:38 AM
Build date:  03B
Shifter code:  19D52P
Post by: bcmiller on April 10, 2016, 01:55:54 AM
Thanks Darrell!
Post by: suturb110 on April 10, 2016, 05:20:23 PM
Early Van Nuys 1969 Camaro Z28
Build Date 09D  (1968)
Shifter Date code  8 8D3
Original Shifter for car
Post by: bcmiller on April 10, 2016, 05:30:53 PM
suturb110 - thanks for your data.  Would you happen to have a pic of the date code?
I think we are starting to see a pattern that some early 69s used the 4 digit date code.  Now hopefully more data will give us the approximate time of the change.
Post by: 69 Zee on April 10, 2016, 06:07:58 PM
Please note that mine is a Norwood production if needed.
Post by: KurtS on April 11, 2016, 02:16:21 AM
Steve (paceme),
Does your Firebird have its original shifter? What's the code?
Post by: suturb110 on April 11, 2016, 04:48:53 AM
Hi,
Attached is a picture of my early 1969 Z28 shifter. Build  code 09D 1968 Van Nuys.  The shifter date code is 8 8 D3. The first "8" was stamped real lightly by the bolt.  The rest of the date code is real clear. After I resized the picture the first "8" got more faint.
Post by: KurtS on April 11, 2016, 06:24:19 AM
Date         shifter
09C NOR   890731C
09D LOS   88D3
12B NOR  68B2
03B NOR  19D52P
07A NOR  690711F
Post by: bcmiller on April 11, 2016, 03:40:15 PM
Minor change to order. Gary has a late car (09C)
Date         shifter
09D LOS   88D3
12B NOR  68B2
03B NOR  19D52P
07A NOR  690711F
09C NOR   890731C
Post by: X33RS on April 11, 2016, 08:02:13 PM
I thought I remembered doing this before??
Car
12D 69 Z Norwood
Shifter
1280D31D
Post by: bcmiller on April 11, 2016, 09:41:45 PM
You may have submitted it before, and we missed it. Sorry about that. We will add it. :)
Data on EARLY cars is the most important for what we are trying to determine.
Post by: 67pacer on April 11, 2016, 10:38:25 PM
Date           Shifter
02C LOS    19D52M
Bill
Post by: X33RS on April 12, 2016, 01:00:37 PM
No apology needed Bryon.  I was just making sure I wasn't losing my mind, lol.
Post by: cruizin69 on April 12, 2016, 01:29:42 PM
The date Code on my shifter is 19D51J from a 02A Z/28
Post by: bcmiller on April 12, 2016, 01:50:32 PM
Car           shifter date
09D LOS   88D3
12B NOR  68B2
12D NOR 1280D31D
02A xxx  19D51J
02C LOS  19D52M
03B NOR  19D52P
07A NOR  690711F
09C NOR   890731C
Post by: bcmiller on April 12, 2016, 01:52:01 PM
LOS or NOR ???  If you can, try to make pic a little smaller next time.  Thanks!
Post by: jdv69z on April 13, 2016, 01:15:21 PM
So attached is a pic of the Hurst shifter from my 69 Z, build 10B, Oct 68. Shifter is dated  6  8B2. The 6 is hard to see. I'm not sure this one is on the list? Sorry if duplication.
Post by: bcmiller on April 13, 2016, 04:05:38 PM
Thanks Jimmy V. I had copied your data over from the shifter report thread earlier.
Post by: JoeC on April 14, 2016, 03:09:20 PM
here are pics of my 78D2
looks original but has some surface rust
so far it looks like 88D3 is the latest 4 digit code and 108D41C is the earliest 6-7 digit code ?
Post by: 69Z28-RS on April 14, 2016, 03:23:10 PM
We haven't been keeping up with it, but are all these '69 Shifter bodies marked '3138', whether early or later ??  Or did they change the model number along with the mfg code  in the September '68 timeframe??
Post by: suturb110 on April 14, 2016, 06:35:08 PM
My 88D3 date coded shifter also has 3138 stamped on the front of the shifter body.
Post by: bcmiller on April 14, 2016, 07:48:12 PM
Most if not all should be 3138 bodies.
Post by: KurtS on April 15, 2016, 04:31:10 AM
I also asked the 69 Firebird guys about shifters. Nothing yet.
Post by: jdv69z on April 15, 2016, 12:47:10 PM
So where's the 3138 stamping? On the front if I'm under the car looking front to rear?
Post by: suturb110 on April 15, 2016, 03:22:09 PM
yes on the front on the shifter.
Post by: JoeC on April 15, 2016, 04:52:45 PM
3138 is the Hurst part number just for that stamped part that makes up the outside case
It was used on many OEM shifters (Camaro Firebird GTO and others)
Post by: Hans L on April 25, 2016, 04:29:25 AM
Here you go - '69 Z, 04B VN, M22 trans:   9D53D
(http://i1061.photobucket.com/albums/t478/jwlittooy/Z28%20Shifter/3bc191c1-416a-4c6e-b589-a5d7d308865a_zpstlkkh7ge.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Z28%20Shifter/3bc191c1-416a-4c6e-b589-a5d7d308865a_zpstlkkh7ge.jpg.html)
Post by: bcmiller on April 25, 2016, 07:02:09 AM
Hans - Can you check to see if there is another digit before the 9 please? It may be very lightly stamped.  Thanks!
Post by: ZLP955 on April 25, 2016, 10:07:59 AM
Is that a faint '1' before the 9D53D?
Post by: Hans L on April 25, 2016, 03:03:25 PM
Will do.   I'll have to crawl under and see now.  The shifter is on the car....but when I blew up the pic above, there does indeed seem to be a faint 1 before the 9...
Post by: Hans L on April 25, 2016, 03:34:10 PM
Found a better pic, so confirming the "1".  Correct code  19D53D....for 04B VN RS Z....
(http://i1061.photobucket.com/albums/t478/jwlittooy/Z28%20Shifter/DSC_9222_zpsahlrukzw.jpg) (http://s1061.photobucket.com/user/jwlittooy/media/Z28%20Shifter/DSC_9222_zpsahlrukzw.jpg.html)
Post by: 69Z28-RS on April 25, 2016, 03:37:04 PM
Finding a better photo sure beats having to crawl under an assembled car to get that info...  :)
Post by: bcmiller on April 25, 2016, 06:13:38 PM
Data so far from known original cars.  Yell at me if I have missed any.  :)
Car           shifter date
09D LOS  88D3
10B NOR  68B2
12B NOR  68B2
12D NOR 1280D31D
02A xxx  19D51J
02C LOS  19D52M
03B NOR  19D52P
04B LOS  19D53D
07A NOR  690711F
09C NOR   890731C
Post by: jdv69z on April 26, 2016, 07:07:47 PM
My 10B on the list (2nd from the top) is Norwood.
Post by: KurtS on April 26, 2016, 07:57:11 PM
Fixed.
Post by: ZLP955 on April 29, 2016, 04:43:25 AM
I cannot say with certainty that it is original to my car, but the shifter that came with it (along with many other original dated parts that were taken off soon after purchase by the original owner) is stamped 29D21C. Will upload a picture shortly once I figure this iPhone out....
Post by: ZLP955 on April 30, 2016, 02:53:47 AM
Here's that date code:
Post by: Steve Shauger on May 02, 2016, 01:45:16 AM
My 69 RAIV Firebird was built 2D and shifter has the typical coding 190423D( Jan of 69). This is the original and includes all orig mounting hardware and linkage.
Post by: KurtS on May 02, 2016, 08:54:58 PM
That confirms is it a model year format change and the format is not dependent on the vehicle application.
Thanks!!!
Post by: DONCZ28 on May 05, 2016, 09:50:54 AM
  I have a 69 z  built 6/24/69 VIN #661208  Hurst shifter  #19D42M
Post by: ko-lek-tor on May 05, 2016, 02:46:36 PM
Just to be sure, you can assure that is the original shifter to that car, correct?
Post by: 69Z28-RS on May 05, 2016, 03:01:45 PM
Jan shifter in a June car?   That's a much larger gap than in any of the others on our list (I think all of which are within a month of car production)...
Post by: bcmiller on May 05, 2016, 10:23:19 PM
Most seem to be within a month or two. There are a couple with 4 to 6 month gaps.
Post by: X33RS on May 10, 2016, 02:30:37 PM
Mine is super close, a 12D car with a 12-68 shifter.  I don't think there is a week given on the shifter code so can't narrow it down further, but my car and shifter are both in the same month of the year so they can't be more than a couple weeks apart.
However, a shifter, or most any other date code spread 2-3 months apart wouldn't worry me much, as long as it's obviously before the car build date.
Post by: DONCZ28 on May 15, 2016, 04:12:18 PM
Have owned this car since 82, and don't believe it was replaced.
Post by: Bryan302 on May 16, 2016, 03:57:29 AM
It seems there are several January shifters in later cars that old eyes couldn't see.  There is an 03B, 04B, 06A.  So, there must have been a very large batch of January shifters.  My 05A Z28 NOR has one, 19D51Q, owned car since April 1979 and prior owners known.  Shifter 100% original.
Post by: cruizin69 on May 16, 2016, 06:48:29 PM
My 02A 5th from the top is a Norwood car
Post by: Steve Shauger on June 02, 2016, 02:54:36 AM
My 6A L78 has a 19D43D
Post by: ZLP955 on June 07, 2016, 09:33:49 AM
Car     Plant    Shifter Date
09D     LOS     88D3
10B     NOR     68B2
12B     NOR     68B2
12D     NOR     1280D31D
02A     NOR     19D51J
02C     LOS     19D52M
03B     NOR     19D52P
04A     LOS     29D21C
04B     LOS     19D53D
05A     NOR     19D51Q
06A     NOR     19D42M
06A     NOR     19D43D
07A     NOR     69O711F
09C     NOR     89O731C
Updated:  June 7 2016 (added 'NOR' for Steve's 06A)
Post by: NorCam69 on June 17, 2016, 03:36:37 AM
05A Norwood Car
19D35E
Post by: ZLP955 on June 19, 2016, 02:35:46 AM
09D     LOS     88D3
10B     NOR     68B2
12B     NOR     68B2
12D     NOR     1280D31D
02A     NOR     19D51J
02C     LOS     19D52M
03B     NOR     19D52P
04A     LOS     29D21C
04B     LOS     19D53D
05A     NOR     19D51Q
05A     NOR     19D35E
06A     NOR     19D42M
06A     NOR     19D43D
07A     NOR     69O711F
09C     NOR     89O731C
Updated:  June 19 2016 (added Earl's 05A)
Post by: Daytona Z on November 04, 2016, 03:07:12 PM
Here's a little food for thought on the coding witnessed on the shifter bodies.
First let me preface this by telling you that a very good friend of mine has taken dozens (if not hundreds) of shifters out of cars when rebuilding Muncie 4-speeds & Hurst shifter bodies at a specialty restoration shop over the past 30+ years. Two people there had often taken note of the codes on the cases and referred to different prefix numbers as being associated to GM, Pontiac, Olds, etc. (i.e. 1=Chevrolet, 2=Pontiac, 3=Olds and so on so forth). It was also said that the second character likely determined the year, and the third related the month. Apparently the coding was done differently in different years where alpha letters were used for the months of one year while numeric values were used in others.
In recent conversation with Peter Serio, the two of us discussed the coding and batch numbers witnessed on different cases and he is certain that different coding was batched for each motor division and that the prefix is likely the plant code ordering the shifter rather than the month which is what many people are thinking the first character was? For those of you who do not know Pete, he like my friend has been active in the restoration field for many decades. He is widely known for his Hurst Shifter restorations within GTO, Firebird, Camaro circles and has restored hundreds and hundreds of different Hurst shifters. Pete is touted as being one of the best and has restored hundreds of them.
Peter Serio
2719 Columbus Ave.
Columbus, OH 43209.
614-258-3500
He's also written books on shifters. http://precisionpontiac.net/Book_Volume1.aspx
Pete understands many of the differences seen in a shifter body that many people truly don't? In a lengthy discussion, he informed me of many changes seen in the shifter bodies between one motor brand and another, and also educated me on the subtle changes made within a shifter body when GM would send change orders to Hurst facilitating things like reverse lockouts etc. When the new columns came out with locked steering in 69, there were problems where people inadvertently locked transmissions up by getting the shifter to engage reverse and forward gears at the same time. This created many issues and potential lawsuits for GM where changes orders resulted in multiple manufacturing changes within the 69 shifter bodies to correct these issues. He went on the tell me that one cannot always take two 69 Camaro shifter bodies apart and attempt to interchange parts because there were various part changes within most years especially in 69. I told him about the date sequence referred to in this page and he strongly suggested it may not be as many people think?
I know another person in the hobby that takes one look at a shifter body and you can ask him, hey what's that from? He'll quickly answer that's easy, 29D coupled with that particular offset is 69 Poncho out of a Firebird while he can look at another body and spit out out 1967 Big Fat Chev. I have spoken to many people heavily involved in this hobby that know Muncies and Shifters intimately and while most have different opinions on dating/coding, the one thing that has been commonly discussed is how most concur that the first character (at least in some years) is related to the motor division.
Just sharing some of what I have learned from a few who are way smarter than I  ;D
Post by: ko-lek-tor on November 04, 2016, 04:20:27 PM
Green NV & Mr Serio, appreciate your insight and experience that gives food for thought. All the dates provided above are supposed to be out of cars that the owners are stating the shifter is the one "born with" their respective car. I have the 12B Nor 68B2 Hurst. By your observation, this is not even a Chevy (1) shifter. So, what is my shifter out of? What would GM division 6 be? Why would it be in my Chevy? And work, fitting the application?
Post by: bcmiller on November 04, 2016, 06:15:59 PM
GreenNV,
You are pretty new here. Did you ever introduce yourself and tell us your background? New insight is always welcome here, just don't try to set the world on fire. Eh?
Your observations are interesting, but don't seem to fit what we have observed in original cars.
Post by: jdv69z on November 04, 2016, 07:26:40 PM
Same coding for my Shifter. The original from a 10B Oct 68 Z, an early car. Reverse lockout does and has always worked flawlessly. I don't see how the shifter could engage 1st and reverse at the same time, but if that could happen, it would be related to the internal rails of the shifter itself, and would be a design flaw unrelated to reverse lockout..
Post by: Daytona Z on November 05, 2016, 02:02:32 AM
Looking at the shifters listed in this thread is only but a small sampling of codes out there and pertains to a couple years and perhaps one model only. While you can conceivably think it could be month, year for maybe 68/69, what about all the other years and codes from all the other motor companies where the coding is very different and 8 characters long? Kinda begs you to ask the question doesn't it? That's why I asked Pete, and he doesn't think it's date coding, but actually batch codes.
Example...what are all these zeros about? Month zero then year??? There's gotta be more to this.
(http://www.yenko.net/ubbthreads/pics/usergals/2016/10/full-1102-51107-imag1062.jpg)
(http://www.yenko.net/ubbthreads/pics/usergals/2016/10/full-1102-51108-imag1059.jpg)
(http://www.yenko.net/ubbthreads/pics/usergals/2016/10/full-1102-51109-imag1057.jpg)
Post by: ko-lek-tor on November 05, 2016, 02:53:46 AM
I'll answer your questions when you answer mine. And when you say this is a sampling of a couple of years and perhaps one model only, that is an insightful observation as this is a 1st Gen site and Hurst usage of one model year. So, yes, that is all I am concerned with and all this site is and should be concerned with. Let other makes/models make their own conclusions. You surely cannot deny the facts of the sampling and you are up against some of the best minds in the hobby. We, collectively, are open minded to divergent viewpoints, and do not have our head in the sand. What you propose is not consistent with the evidence. Do you see a pattern from the data that suggests different?
Post by: X33RS on November 05, 2016, 01:06:56 PM
I believe everyone could be right.  It does seem odd to me how some shifters do have extra characters while others don't.   And as far as I know there hasn't been a complete breakdown or understanding posted on the site anywhere that I've seen. I don't think it's all completely understood yet.   Just looking at the list, mine is the only original shifter on that list with 8 characters.
I tend not to believe the first digit is a model number, nor is the second digit a year in my case.  Looking at mine for instance you have to look at the first 3 digits.  It's the only shifter in the list that belongs to a December built car.  Therefore the only explanation that makes sense to me at this point is looking at both the 1st and 2nd digit together.  That looks like a month to me (December)   The 3rd digit on mine would be the year (1968)
   I have no idea what the "O" is and a pair of D's don't make much sense to me either.   But I could make a good guess at the 31 as possibly being the day of the month since my car was built around the last week of December.   That's just a guess but it makes the most sense to me at this point.
Post by: 69Z28-RS on November 05, 2016, 02:02:22 PM
I agree with X33 ... as I've stated before.   The Hurst code is not ONLY a date code; it makes more sense that it's a Hurst batch code, BUT it does have a 'date' encoded into it (I don't think there's any doubt about that, at least for the Chevy shifters for '69, where we have TOO many examples to ignore.  Th fact of a date included batch code makes sense given the warranty issues that would be faced when Chevy sent back to Hurst a malfunctioning Shifter from a 'warranted' car for repair/replacement.  Hurst would have a means to determine from only the shifter 'when' it was made and how long any warranty Hurst supplied to Chevy would last.
Post by: jdv69z on November 05, 2016, 04:06:48 PM
Without a doubt Gary.
Post by: Daytona Z on November 05, 2016, 04:12:05 PM
Not only that, but those stamped numbers would had to have had successive coding for versions of the same shifter series. Pete Serio told me of at least 3-4 changes in the 69 model year alone due to all the change orders GM sent to Hurst regarding the column lock and the changes that brought throughout the year. I would bet one of those characters in the stamp is the series for revisions. I'd guess it was the first because of the 1/2/3 but then why the 6 or 8's later in the year? Or are there actually other prefixes such as 4/5/6/7 that we simply haven't seen yet.
Here's one from another 69 that starts with a 3.
(http://www.yenko.net/ubbthreads/pics/usergals/2016/10/full-1402-51205-pa290014.jpg)
So much is still unknown about shifter coding, dates and batch codes or series? It's fantastic to have CRG and its members compiling data such as this, but there's a lot more remaining to be learned before attempting to pull an actual date from this code, or how it can actually be deciphered.
Post by: 69Z28-RS on November 05, 2016, 04:42:00 PM
GreenNV:   The one you show fits perfectly with the encoding we've determined (from original '69 cars/shifters).   The first (one or two digits) is the MONTH, the 2nd (or third) digit is the YEAR.   The one you show is for March of 1969...  the following characters/digits are perfectly able to account for 'versions' or 'batches' that seemingly only Hurst knows about at this point in time.. :)
Post by: bcmiller on November 05, 2016, 07:03:43 PM
Generally, at this point, we are looking at codes from 69 Camaro Hurst shifters. I am pretty sure coding changed for 70 and later. Let's try to not muddy the water too much. Let's stick with original Hurst shifters from original 69 Camaros.
Post by: X33RS on November 05, 2016, 09:08:25 PM
I think you're right Gary.  If you look at the first 3 codes on mine (128)  December 1968 is the only thing that makes sense.  So I believe looking at the shifter posted just above, I agree that would likely be a March 1969 shifter.
Bryon, I have another factory Camaro Hurst that has an original 70 Camaro stick in it.  I believe that shifter body is dated very late in the 69 calendar year.  Might have a slightly different sequence of numbers if I remember right.  I'll leave that out of the conversation for now.  But if it becomes crucial to determining any information on numbers/letters and how they might of changed, I'll dig it back out.
Post by: bcmiller on November 05, 2016, 09:52:15 PM
You can dig it out and post if you want. At the beginning I had posted a couple of Pontiac shifter codes.
Other GM divisions were using Hurst shifters several years before Chevrolet.
I just don't want us to lose focus. No we don't understand everything, but I feel we are on the right track with the date codes used for 69 Camaro Hurst shifters.
Post by: KurtS on November 08, 2016, 03:46:45 PM
Agreed. Why there other formats in non-69 Camaro shifters is not part of this discussion. Showing some examples from other known original shifters is fine, e.g. here is a 68 F-bird 03C shifter.
Post by: cook_dw on December 02, 2016, 02:10:02 PM
Unknown.
Post by: JoeC on December 06, 2016, 09:52:23 PM
something I noticed over the years working on Hurst shifters
they changed from sliver cadmium plate to black phosphate about 1970 from what I can tell
the aftermarket shifters also changed from sliver cadmium plate to black phosphate
I think HURST worked in the change over a period of time because they had so many different shifters
Post by: Daytona Z on December 09, 2016, 11:47:10 PM
Another 69 shifter. This is a restored one I picked up for my 69 build and will be going into my 05A car. I'll need to find some original bolts for this one before mounting it up.
(http://i1218.photobucket.com/albums/dd418/DBL_NKL/My%20Cars/69%20Z28/IMG_3689.jpg)
(http://i1218.photobucket.com/albums/dd418/DBL_NKL/My%20Cars/69%20Z28/Shifter%20Body.jpg)
(http://i1218.photobucket.com/albums/dd418/DBL_NKL/My%20Cars/69%20Z28/Date%20Code.jpg)
Post by: bcmiller on December 10, 2016, 12:43:46 AM
If possible, I would like to see any additional posts be from original cars with original shifters.
Thanks.
Post by: Daytona Z on December 10, 2016, 01:53:29 AM
You can delete that post then.
It's one number off the original from my car and thought the more you can learn about dates the better, but I guess this thread is only for original "born with" shifters for the 69 model year only then?
Post by: bcmiller on December 10, 2016, 02:16:26 AM
Well since this is a First Generation Camaro website, and the only Hurst shifters that we are doing research on are from 69 Camaros, yes. That's what we have determined in this thread that we are concentrating on, and we are trying to figure out the stamping codes. Unknown shifters don't help much.
My earlier post was a REQUEST, not a demand.
Thanks.
Post by: hihorse on May 11, 2017, 12:23:19 PM
Original shifter from 2D '69 Camaro 29D34E
Post by: Daytona Z on October 29, 2019, 03:06:37 AM
Here's an original 3138 Hurst that's currently within a late 69 Camaro Z/28 that I recently acquired and thought I would share because it's a late build. Car is a 10E build from early November 69 and it appears the shifter and trans have never been out of the car with original hardware and all linkages including lockout in place. Hope this date codes helps.
(https://i.ibb.co/Jnb4Lxv/020.jpg)
Original transmission, shifter and bell housing in place.
(https://i.ibb.co/hVqtf7w/IMG-7098.jpg)
Original Muncie M20
(https://i.ibb.co/x6dy6Vh/IMG-7174.jpg)
Stamped 990732M and original to this late 69 car
Post by: luv2sixty9 on October 31, 2019, 01:28:13 AM
Sept 1969 Shifter
Post by: x77-69z28 on October 31, 2019, 10:34:26 PM
Graeme, great to see you over here as well! Love your new ride! There is a lot to learn from that one.
Buddy
Post by: JoeC on November 01, 2019, 03:48:21 PM
can you tell if there is rubber on the forward levers on the hole where the shiftier rod is installed ?
the assembly manual looks to show no rubber and used a spring washer but some cars have been found with the rubber on the lever
I have seen both types of forward levers (with rubber and without)
pics show the two types of levers
Firebird and GTO used the levers with rubber also
Post by: bcmiller on November 03, 2019, 04:32:55 PM
Good information Joe. It’s good to see this thread that we started is still active.
Post by: JoeC on November 07, 2019, 01:24:58 PM
We should add levers to the 1969 shifter report but I'm not sure if the 69 Camaros should have the rubber on them or not
The assembly manual shows no rubber on the levers.
It shows spring washers which are not normally used with rubber
The metal levers are the same with or without the rubber molded on them
1968 and 1969 GTO and Firebird used the rubber coated levers
Some original looking 1969 Camaros have shown up with the rubber on the levers
not sure if the rubber ones were sold as service parts or something
Post by: BULLITT65 on November 07, 2019, 05:39:54 PM
I have the rubber on my early 69Z, and wasn't sure it was original since I hadn't seen them before, until this thread appeared. One issue I have is while everything appears to be original, my reverse shift rod appears that it is the right shape, but a couple inches shorter than the ones shown here. Can anyone measure theirs for me?
(With the alignment pin in the linkage, I barley have enough threads to get the nut on)
Post by: JoeC on November 07, 2019, 09:48:41 PM
the Rev lever in my picture measures 3 3/16 in long
also interesting that many original Rev levers I have seen are black oxide and forward levers are silver cad plated
Post by: JoeC on November 07, 2019, 09:53:29 PM
opps you asked for the revese rod
mine measures 8 5/8 long and is stamped 5771
Post by: Daytona Z on November 08, 2019, 03:41:22 PM
Buddy
Thanks Buddy. I always drop in here to fact check things and see what's going on every once in a while, but I'm mostly on sYc. Both are great sites.
JoeC...
Here are a few pics I grabbed when the car arrived a couple weeks ago. Not the best pics but clearly, there are no rubber insulators on the shift levers on this 10E car.
(https://i.ibb.co/jZgxSXB/IMG-7099.jpg)
(https://i.ibb.co/4fZGCKq/IMG-7098.jpg)
(https://i.ibb.co/MD0CSS0/IMG-7097.jpg)
Post by: Daytona Z on November 08, 2019, 04:10:28 PM
And here is a close up of the shifter legs and the original rubber insulators.
(https://i.ibb.co/zZJWLLN/IMG-7379.jpg)
Post by: BULLITT65 on November 08, 2019, 04:14:04 PM
Thanks Joe. What month was the car produced? I only ask because looking at reply 88 from Green NV 10E car, his rods have a lot of thread showing after the nuts.
Post by: JoeC on November 08, 2019, 08:02:10 PM
I don't have the car , just have the shifter
it is a June 1969 date code
it looks all original and complete
it does not have the rubber on the levers
even has the original alloy ball
don't forget that you can adjust the shifter forward or back because the lower shifter bolt on the mount plate is in a slot.
that will make your rod adjustment longer or shorter
if you have a console , you may not have much room to adjust it
Post by: BULLITT65 on November 08, 2019, 09:31:39 PM
Ok just got some more info.Crawled under the car and cleaned up the linkage enough to get the date code:
10B Los Angles car
date: 8 8 D 4
I also see the part number 3138 on the front.
So it seems to line up ok date wise, based on the other examples
Joe, no console, and I see your point on the adjustment plate.
So measuring my rod, I am only getting 8 3/8, and I do not see a part number on it. Looking at your pic my rod looks slightly different.
Could the rods have been different for the early cars?
(fyi I only have the rubber on the linkage, I don't see any rubber grommets on my trans shifter key ways.
Also all my rods are held with cotter pins. When did hurst start using the spring clips?
Post by: JoeC on November 09, 2019, 04:47:57 PM
I have not seen different length small block rods
big blocks rods are different length
was yours cut off or ground down on the end?
the Hurst spring clip was out well before 1969
The spring clip should not be used with a rubber bushing
the rubber bushing used a flat washer
the levers with no rubber used a flat washer and a spring washer
see the assembly view in the CRG Shifter report here
http://www.camaros.org/shifters.shtml
Post by: BULLITT65 on November 09, 2019, 05:28:15 PM
Thanks I have read that page a while back. While my rod does not exactly look like yours, when I went back to the shifter page it does look spot on to the one pictured, ( slight angle on the trans side of the rod pin mount) and as the research article says some did not have part numbers stamped in them.
 I also assume you mean no rubber, flat washer spring clip.
So since the transmission side of the linkage does not have rubber on the shifter key ways, did any of these get the steel shifter bushings and spring clip?
Post by: JoeC on November 10, 2019, 06:03:46 AM
no, I do mean spring washer not a spring clip
the 1969 assembly drawing shows the trans levers with no rubber used  a spring washer, a flat washer , and a cotter pin
the shifter levers with rubber used a flat washer , and a cotter pin
Post by: bcmiller on November 10, 2019, 02:05:36 PM
Yes that it what I have seen too Joe. Flat washer and cotter pin on those with rubber - most common with GTO shifters.
Post by: BULLITT65 on November 11, 2019, 12:37:17 AM
thanks Joe I will review the AIM
Post by: BULLITT65 on November 12, 2019, 03:57:05 PM
09D     LOS     88D3
10B     LOS     88D4
10B     NOR     68B2
12B     NOR     68B2
12D     NOR     1280D31D
02A     NOR     19D51J
02C     LOS     19D52M
03B     NOR     19D52P
04A     LOS     29D21C
04B     LOS     19D53D
05A     NOR     19D51Q
05A     NOR     19D35E
06A     NOR     19D42M
06A     NOR     19D43D
07A     NOR     69O711F
09C     NOR     89O731C
Updated:  Nov 12 2019
Post by: rszmjt on November 24, 2019, 08:09:41 PM
My 06A Z28 shifter is 19D51C, Owned the car since 1974, and the rod clips are flat type clips, not hurst spring type or cotter pins.
Post by: cruizin69 on December 16, 2019, 07:41:12 PM
Build date:  03B
/quote]
Build date: 02A
Shifter code: 19D51J
Post by: cruizin69 on December 16, 2019, 07:50:52 PM
My 02A Z/28 is Norwood car shifter 19D51J
Post by: COPOZ/28 on March 09, 2020, 03:26:24 PM
Here's the info on my '69 Z and shifter.  Am the 2nd owner since Nov of '79.  Knew the 1st owner very well and helped him order the car, including the 4.88 axle ratio via the COPO system.  The car's block/fitted pistons were replaced under warranty in the spring of '70 due to a loose wrist pin retainer scoring a bore.  After getting the car back from the dealer, the 1st owner removed the engine/trans and prepped the car for drag racing (decked the "CE" block, honed extra piston to wall clearance, changed the 4.88 gear to 5.38, etc., etc.)  I helped re-assemble the engine and get the car back together.  The car ran 113 MPH at Van Wert Dragstrip in NW Ohio but didn't ET well -- my friend weighed 300 lbs and did not have the assistance of Bill Jenkins building/tuning the engine and chassis, like his hero Dave Strickler had. The car was not licensed or driven after 1972 and sat until I circled back to buy the car in '79.  All of this is not proof of the shifter being original to the car, but with the M22 and rear axle being original to it, one does wonder.  Shifter attachment bolt heads can be seen in the attached photo -- do they appear as the correct fasteners?  I'm asking as both the engine and trans had been taken out of the car at least twice (once by dealer in early '70, once by 1st owner in mid-summer of '70) before my purchase in '79.  I've done it at least twice since then.
Many thanks to everyone who helped make, and continue to make, this forum the remarkable reference site it is.  I "found" it only just recently and promptly joined, and have already benefited greatly from the knowledge contained throughout the site.  My interest in learning more about my car runs in spurts, having owned it for so many years.  Right now, I'm definitely in the middle of another "spurt!"  Thanks again.
05E NOR Build
19D51Q Shifter code
3138 Stamping appears on front of shifter body
Shift levers have the molded in rubber style inserts
Shift rods attached via curly round wire (aka Hurst?) spring clips without any washers
P9E14C Stamped trans code (VIN stamp matches car VIN)
3950318 Trans metal ID tag
BX 0429 G2 E Axle code stamping on tube
Post by: Jonesy on November 23, 2021, 10:55:02 PM
My 1969 Van Nuys Z28 02A has its original shifter and the stamping on the body is 19D33D
