Author Topic: Heater hose retainer  (Read 9284 times)
Ejam
« on: February 11, 2016, 09:07:38 PM »
Does anyone know what fastener is used for the heater hose retainer on the rd wheel housing?  The retainer l have has a round hole and housing square. 69 SS 396 no AC
Re: Heater hose retainer
« Reply #1 on: February 11, 2016, 09:16:31 PM »
Ejam
« Reply #2 on: February 11, 2016, 09:18:19 PM »
There is no bolt?
« Reply #3 on: February 11, 2016, 09:19:37 PM »
unh uh, nope, nada. If you look close along the bottom straight side, there are two tangs that , like a spring loaded effect, snap into that hole...ain't Chevy smart?
Ejam
« Reply #4 on: February 11, 2016, 09:23:12 PM »
Ok cool thanks.
Ejam
« Reply #5 on: February 11, 2016, 09:25:50 PM »
If l knew how to put up a picture l would show my retainer. Doesn't have that at all
m22mike
« Reply #6 on: February 11, 2016, 10:18:00 PM »
I would look for a good used on, plenty out there, when installed correctly they are very tight, hammer and dolly as needed. Same tabs as the sppedo clips.
KevinW
« Reply #7 on: February 12, 2016, 12:27:37 PM »
Sounds like the heater hose retainer that bolts to the top of the Alternator (for 69s).  Its a small "recessed head" bolt that fits into the threaded hole on top of the bracket.
Best pic I could find online
« Reply #8 on: March 09, 2017, 12:50:53 PM »
That fastener that holds the hose retainer on the alternator, does anyone have the GM number or AMK? Or a detailed picture? Thanks.
ssl78
« Reply #9 on: March 09, 2017, 03:21:14 PM »
Not all cars had the bracket by the alternator if your car is original see if the bracket hole has threads for a bolt
« Reply #10 on: March 09, 2017, 03:57:10 PM »
Even though it's not in the AIM (inadvertently left out), all 1969 Camaro V8 cars got this bracket. However, that being said, you can still see it in the AIM under UPC C60, Sheet D7, items number 9 for the "Clip" (P/N 3825416) and 8 for the "screw" (P/N 9420152). The specs for the screw is 1/4-20 x 1/2" and a good picture of it is in THIS THREAD.
« Reply #11 on: March 09, 2017, 06:32:20 PM »
thanks a bunch Ed.
