Main Menu
Heater Hose Bracket Bolt
Started by camaronut, January 04, 2007, 09:03:24 AM
Previous topic - Next topic
camaronut
Can anyone tell me what the correct bolt that is used that holds the heater hose bracket on top the alternator bracket on a 69 Camaro 350?
Is it a 3/8 or 5/16 indented head bolt? ???
Thanks...
camaronut
#2
JohnZ,
Thanks for the reply.....would the head of the bolt fit a 9/16" socket or 1/2" ???
Is the correct bolt available???
Quote from: camaronut on January 04, 2007, 11:38:42 AM
JohnZ,
The hex head takes a 3/8" socket - try AMK Products (www.amkproducts.com) for a similar replacement; spend the money for their catalog - it's worth it.
RamAirDave
Also, when/if you order from them, just ask for a catalog.  They wont charge for it with an order (they didnt for me).
www.TheMuscleCarGuys.com
Dave69x33
Attached are pics of the screw on my 69Z, Norwood car assembled 05A.  The only place in the 69 AIM I could find the GM part number of this screw was page 223, under the C60 option covering the AC system.  P/N-9420152 screw and P/N-3825419 clip are called out.  AMK unfortunately does not have a listing for this screw which would show the screw, but they do have the heater hose clip (AMK item #B-10005 if you look for it on the on-line catalog, or p. 151 in their catalog).
The screw is a self tapping, 1/4-20 x 1/2", with indented head and the manufacturer's marking "RBW".  AMK bolt #B-12302, 1/4-20 x 1/2", indented head with "NL" markings and an encapsulated lock washer is close.
Any time I find a survivor Camaro that still has its original hardware still in tact, I try to get pictures. Unfortunately, this screw is often removed and lost because it along with the alt. bracket is removed for a number of maintenance related jobs. I do have pics of this screw from some "top notch" restored cars, but the RBW screw was "the original" according the owner and replated.  So that is all I have to go on at this point.
Does any one have their original, or pics or an original, screw?  Pics of this screw along with a note on the build date and plant would be great!
Paragon has that exact same screw, their #1189K, 7 bolts for $5.00 - it was used on midyear Corvette radio ground straps and the front crossover brake line clip, and has the RBW headmark.
RamAirDave
#7
Good to know, something I will correct in the near future.
As far as the two heater hose brackets (alt and inner fender), I Palmetto ZnPh both of them.  I dont think that is necessarily correct, but was more of a test than anything else, just to see how it would look.
The alt bracket looks light in color in that pic, but is the same as the inner fender bracket.  Just dont have a detail pic of it.
Were both of those black paint?  I'm pretty sure the answer is "yes", just wanted to make sure.
camaronut
Thanks to all..
I thought that it was a 3/8" bolt, not a 3/8" head.
I almost drilled my original to fit a 3/8" bolt, indented head which was 9/16"
Now I'm straight....
Quote from: RamAirDave on January 08, 2007, 02:12:24 AMAs far as the two heater hose brackets (alt and inner fender), I Palmetto ZnPh both of them.  I dont think that is necessarily correct, but was more of a test than anything else, just to see how it would look.The alt bracket looks light in color in that pic, but is the same as the inner fender bracket.  Just dont have a detail pic of it.
Nope, not painted - they were both dark phosphate-plated; the color of the inner fender bracket in the photo looks about right.
