Author Topic: PB Booster Hose Support Bracket  (Read 11283 times)
69 Zee
« on: July 21, 2015, 02:25:45 PM »
Awhile back, going thru some parts I discovered I had another brake booster hose bracket.  I compared it to my original bracket from my '69 Z.  To my surprise it's a dead ringer in every way, shape and form.  Even has the little tab at the top (near the hose hole).  EXCEPT,  it doesn't have the "AAC" stamp on it.  It even carries the same corrosive look as my Z's.
I've never seen a repop look this good and it looks to old to be a repop.
Could this still be an original bracket without the "AAC" stamp ?  Were there also multiple suppliers for this bracket thus not having the "AAC" stamping ?
In the first pic you can see the bottom is my "AAC" stamped bracket.  And if I didn't indicate which was the AAC stamped bracket in the others,  I don't think you could tell which is which.
Thanks in advance
Darrell
dannystarr
Re: PB Booster Hose Support Bracket
« Reply #1 on: July 21, 2015, 05:28:22 PM »
I have never seen one NOT stamped. I have seen MANY online for sale over the years. Which doesn't really mean anything. I have 3 of these, and my buddy has two. All 5 are stamped. But of course that is JUST 5 out of hundreds, maybe thousands. I will post a picture of the original one on my '68 Z/28. Then comparison photos with repro's.. By the way, yours does look original to me, but has slight differences in the casting... Danny
dannystarr
« Reply #2 on: July 21, 2015, 05:36:38 PM »
repros next to originals... D
dannystarr
« Reply #3 on: July 21, 2015, 05:38:51 PM »
more
69 Zee
« Reply #4 on: July 21, 2015, 05:56:37 PM »
Yeah,  I have a repop also and there's no comparison.  As stated earlier, I've yet to see a repop come close to an original.  I believe Chevelle's, Nova's and most likely the Birds all used the same type bracket.  I just can't see them getting the same brackets but w/o a stamp, meaning I don't think only Camaro's got the "AAC" stamped brackets.  Or did they ?  I'd think they'd be all the same since there's nothing special to them.
Hmmmm !
Darrell
« Reply #5 on: July 22, 2015, 09:23:28 AM »
Numerous differences, but the location of the bend in the central part of the bracket is the most obvious way to identify the vast majority of repros.
I wonder if that non-stamped bracket is an original part. Other parts that were typically stamped AAc include the front and rear license plate brackets, my front one has the stamp but the rear does not. It's still original to the car, but many I have seen do have the stamp.
« Reply #6 on: July 22, 2015, 01:20:23 PM »
 IMO, that unstamped bracket may very well be an original one that either has no stamp -or- it is lightly stamped in an alternate location.
 It looks too accurate to be a reproduction.
dannystarr
« Reply #7 on: July 22, 2015, 04:10:42 PM »
I agree with the last statement. It has ALL the right looks to be an original. But again, I have never seen one not stamped. I would use it on my car no problem. D
69 Zee
« Reply #8 on: July 22, 2015, 06:06:05 PM »
Tim, I agree.  That center bend is never correct on repros and is always crisp looking.  I'm away for the day but tomorrow I'll post another pic of the brackets inside one another.  They are an "IDENTICAL" fit as they would be if made from the same machine.  I'm 105% certain it's original, but to what ?  Weren't these brackets made for several years ?
Darrell
« Reply #9 on: July 22, 2015, 07:04:41 PM »
Heartbeat City reproduction bracket...
« Reply #10 on: July 23, 2015, 09:37:42 AM »
I bought one from Tamraz a few months ago just to see how it compared, and the bend was much closer to the location on the original brackets than the HBC, Paragon and various others. But still very easy to ID it as a repro.
« Reply #11 on: July 23, 2015, 01:11:24 PM »
I agree with Mike on this....   repros are never that accurate....  :)
69 Zee
« Reply #12 on: July 23, 2015, 11:19:00 PM »
Here's the 2 brackets inside one another.   The "AAC" stamped bracket at the bottom .... Perfect fit !   :)  I also cleaned up the other with a brash brush and there's no markings anywhere.
I assume these brackets were made from a die and punch machine with the stamping incorporated.
Darrell
zman1969
« Reply #13 on: July 28, 2015, 12:36:24 PM »
I think you have another original just unstamped, good find
Rich
69 RS/Z DZ302 Daytona bumble bee
69 T/A clone LS6/6sp
69 Nova SS 396
« Reply #14 on: July 28, 2015, 05:25:06 PM »
The stamp on these brake hose brackets (where present) appears to always be in upper case letters (AAC), yet the stamp on the F&R licence plate brackets has upper case 'A's but a lower case 'c' (AAc). Anyone else noticed this? And what was the name of the manufacturing company that AAC/AAc represents?
