Author Topic: Clutch Return Spring Installation with Headers in '69 Camaro Z/28  (Read 16706 times)
jmcbeth
  • 1st and 5th Gen Camaros
The normal clutch return spring hooks between the clutch fork and the left engine mount. With headers, however, the straight line path between these two points is obstructed by the headers. I've seen a couple of solutions that don't work well. One was to run the spring between the header pipes. Every time the clutch pedal was pressed, the spring scraped against the headers. Does anyone know of an elegant way to solve this problem?
John
1969 Camaro Z/28 RS
Numbers Matching
Re: Clutch Return Spring Installation with Headers in '69 Camaro Z/28
« Reply #1 on: November 08, 2006, 03:09:23 PM »
I reversed the clutch spring and the extension rod... then looked for a direct route where it would not rattle against the header... I will see if I can take a photo of where I ran the rod and spring...
jmcbeth
« Reply #2 on: November 10, 2006, 01:47:52 PM »
Firstgenaddict,
Thanks for the clever solution. A picture would be great.
John
1969 Camaro Z/28 RS
Numbers Matching
« Reply #3 on: November 15, 2006, 02:40:29 PM »
Here is one from the bottom of the car looking at the clutch spring...
Here is another taken from about where a power steering pump would be...
GaryL
  • Marilyn and me
« Reply #4 on: November 15, 2006, 08:53:44 PM »
I made a little bracket out of flat bar and used the motor mount bolt to hang the bracket. I drilled a 1/8" hole on the end. the spring was moved doen enough to clear the headers. I have Thorley Tri-Y's. I aslo have the backdrive working.
Gary
