Author Topic: My New '68 Camaro Z/28 Butternut Yellow  (Read 527638 times)
ZLP955
Re: My New '68 Camaro Z/28 Butternut Yellow
« Reply #60 on: July 19, 2014, 03:22:04 AM »
Danny the yellow markings on the subframe is the date code, there was a thread on this subject here or at TC so I'll see if I can find & post the link. But from memory, the date codes pictured in that thread were on 69s and located on the drivers side where the bumper bracket attached.
Tim in Australia.
dannystarr
« Reply #61 on: July 19, 2014, 05:08:41 AM »
Hey George, yes it is a blast. I am not feeling to bad. Don't have the strength I did but making it happen the best I can. Trying to forget about the 66 THOUSAND dollars in hospital bills, AFTER insurance. The girlfriend is awesome! And for sure a keeper. Thanx...
 ZLP I figured it was some kind of a date code of course cause it has a '68 at the end. But I had never seen anything like this. This car has a lot of cool stuff when it comes to numbers. More to come.
dannystarr
« Reply #62 on: July 19, 2014, 05:19:01 AM »
Pitman arm, Idler arm, Motor mounts, Steering arms, Caliper brackets, Backing plates
dannystarr
« Reply #63 on: July 19, 2014, 05:21:52 AM »
more, Coil Ballast Resistor marked Delco Remy,
dannystarr
« Reply #64 on: July 19, 2014, 05:25:10 AM »
Inside front fender, mounting fasteners of Z/28 Emblems
dannystarr
« Reply #65 on: July 19, 2014, 05:30:31 AM »
more steering and front end part numbers
dannystarr
« Reply #66 on: July 19, 2014, 05:36:33 AM »
more... Piece of black tape under right side of deck lid under spoiler. But not on left side?
dannystarr
« Reply #67 on: July 19, 2014, 05:38:15 AM »
more
« Last Edit: July 19, 2014, 06:15:48 AM by dannystarr »
dannystarr
« Reply #68 on: July 19, 2014, 05:44:35 AM »
under rear spoiler
dannystarr
« Reply #69 on: July 19, 2014, 05:50:52 AM »
Voltage Regulator, Horn Relay
dannystarr
« Reply #70 on: July 19, 2014, 05:51:42 AM »
more
ZLP955
« Reply #71 on: July 19, 2014, 05:56:01 AM »
Danny, found the thread discussing subframe markings - link here:
http://www.camaros.org/forum/index.php?topic=11678.0
Tim in Australia.
dannystarr
« Reply #72 on: July 19, 2014, 06:01:19 AM »
Awesome, thank you, will go there now and check it out... Then gotta hit the sheets...
dannystarr
« Reply #73 on: July 19, 2014, 06:17:01 AM »
Rear Brake Drums and 46 Year Old Brake drum " BU " Sticker - Right Side
« Last Edit: July 19, 2014, 06:54:28 AM by dannystarr »
dannystarr
« Reply #74 on: July 19, 2014, 06:22:40 AM »
Starter and solenoid - Starter Support Stabilizer Bracket
« Last Edit: July 19, 2014, 06:53:03 AM by dannystarr »
