Author Topic: 1969 Z/28 Original Glass Questions  (Read 18158 times)
doomer
« on: September 19, 2012, 06:58:42 PM »
Who would have thought a little rock could start so much research?
I took a rock into my windshield recently, and started checking into replacing the glass. Of course, the glass does not appear original. It is 1971 date coded replacement PPG glass. It reads:
        DUPLATE
PPG LAMINATED
     SAFETY FLOAT
    AS1 M25 25 101
           DOT 18
My other glass does not appear to have markings, except one side window, which says:
           SOFT-RAY
SAFETY  L   FLOW-LITE
               O
AS-2           F          TV
      SOLID TEMPERED
          DOT 15 M75
The problem is that the rear side glass is dated TV (AUG 1969). My car is an 04C car! I'm beginning to think that no glass is original. I've not noticed the mix of tinted and clear until now. I thought that non-A/C cars shipped with clear glass. However, isn't tinted glass an option that a Z/28 may have had?
Since clear glass is much more expensive than tinted, should I just begin the process of going all tinted by replacing the windshield with tinted glass?
Thoughts?
D
doomer
Re: 1969 Z/28 Original Glass Questions
« Reply #1 on: September 19, 2012, 09:21:39 PM »
Interesting enough, I have found the markings on my other windows. All glass is PPG except one (drivers rear side window) which is tinted LOF. So I am going to stick to the original clear glass.
Does anyone here have original PPG untinted front glass in a 69? I'd love to see a picture of the date code/markings. CRGs gallery does not have a photo sample of this type.
« Reply #2 on: September 19, 2012, 09:24:48 PM »
Bummer about your windshield. Yes tinted glass was an option on the Z/28. You had 3 choices: None of it tinted, all of it tinted, or you could have just ordered the windshield tinted. Since it seems most of your glass has been replaced, unless you have some original paperwork it may be tough to figure out what was original to your car. I am unaware if one is more than the other as far as replacement costs are concerned. It wouldn't take extremely long to start looking for original glass though other than the windshield. I have been looking for an original tinted windshield and haven't had any luck.
I have an 08C car and my original glass is dated XV IV and back glass is dated NV. (june, feb, and jan of 69) So you could look for original glass that just predates your build date. Since your car has glass you could replace each piece as you find the correctly dated pieces. OR you could just order all of it reproduction of coarse.
hope this helps
ANYONE OUT THERE WITH AN ORIGINAL TINTED WINDSHIELD FOR SALE OR TRADE?
doomer
« Reply #3 on: September 19, 2012, 11:33:07 PM »
Thanks. After closer inspection, I found that my other windows appear original PPG, all dated close to each other. *Driver door 26 19, Passenger Door 26 29, Passenger rear 27 29, Backlight 26 19) but the driver rear side window is the lone tinted LOF dated TV. It is my guess that the windshield was replaced in the early 70s, and the drivers rear side was replace by glass from a salvage yard at some point.
So now I think my best option is a repop windshield that is date coded to match, and later a new drivers rear side that is untinted and date matched.
LM69Z28
« Reply #4 on: September 20, 2012, 12:39:30 AM »
How about an Oct 68 dated green tinted rear window?.....I know this is not a sales forum so please contact me off board.
Michael Kellogg
LM69Z28
« Reply #5 on: September 20, 2012, 12:42:29 AM »
I don't have one, but you say "green" tinted. Was there more than one kind of tint available?
IZRSSS
  • Guest
« Reply #6 on: September 20, 2012, 01:14:16 AM »
Look under the heading; GM Marks (Tinted OEM glass of this era was green in color, whereas current Soft-Ray glass is blue). http://www.camaros.org/glass.shtml
Probably more info then you guys need but when you have time...fascinating read!
doomer
« Reply #7 on: September 20, 2012, 01:23:11 AM »
Definately a good read' but the photos section needs some ppg photos. I've tried to take some pictures but the lighting makes it very tough.
« Reply #8 on: September 20, 2012, 01:39:37 AM »
Ok, I understand , thought there was a change mid production from the way the request was worded. Thank you for the clarity!
 I feel like I need to buy a whole project car or parts car just for the correct green tinted windshield, with the correct band at the top.
IZRSSS
  • Guest
« Reply #9 on: September 20, 2012, 01:45:48 AM »
It just takes a little patience & about 100 pics per glass & one case of batteries  ;). Actually it isn’t that bad. Turn off all the lights (assuming your car is in a garage), use a drop cord light at the correct angle to illuminate the mark (inside/outside of car depending on the mark), take the pic opposite the side your light is on, w/o a flash. Sounds easy now but it truly was a major PITA!
IZRSSS
  • Guest
« Reply #10 on: September 20, 2012, 01:46:37 AM »
...Back light;
IZRSSS
  • Guest
« Reply #11 on: September 20, 2012, 01:54:40 AM »
I feel like I need to buy a whole project car or parts car just for the correct green tinted windshield.
I think we've all felt that way a time or two, or three, or... about most thing First Gen... ;)
« Reply #12 on: September 20, 2012, 06:23:13 AM »
Besides being easier on your eyes, tinted glass has another advantage over clear..    it provides great protection for the interior materials from the sun's uv rays...  interiors in tinted glass cars are always much better than clear glass cars (at least down here in the south)...
Gary
MyRed67
  • SZZLN 67
« Reply #13 on: September 20, 2012, 06:52:44 AM »
doomer>>>>>>>
  What area do you live in?   I can verify psautoglass.com I got a Dated Windshield there for my early '67 Coupe, it is right on.  Guys name is Mike Wimmer he is very knowledgeable on these date codes.  Located in Janesville, WI. just south of Madison.  I live right in the area, was able to save shipping.   My car also had all original glass, but windshield was  cracked.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
doomer
« Reply #14 on: September 20, 2012, 11:26:01 AM »
doomer>>>>>>>
I'm in the SC lowcountry. I read a few posts that mention psautoglass and actually gave them a call. Unfortunately, after shipping and installation, the cost was very high compared to a reputable installer I found locally, who can obtain good glass and have the correct date code added for me. The only problem is that I do not have a good example of the original markings for PPG untinted windshield glass. I'm really hoping someone here who has such can provide a photo for me. The supplier needs it to make sure the markings he does are accurate.
I never expected clear glass to be so much higher than tinted. If you asked me a week ago, I would have guesses tinted would be the one that was $100-$200 higher. Seems very little clear glass has been reproduced over the years.
