Main Menu
Any 69 owners out there to check something?
Started by boomer632, June 18, 2025, 11:59:22 AM
Previous topic - Next topic
boomer632
I had some electrical gremlins with the horn / key buzzer while installing the tilt column but have since figured it out.. I think. I was able to get hands on a 1969 tilt column.. dated and has the square shaped perch where "lock" is cast. Anyways, horn and key buzzer are now working. I wanted to confirm a funtion of the system as I have never done this prior to the installation. I would like to know what happens when:
1) Key is fully inserted into ignition
2) Door is open and buzzer is activley buzzing
What do you hear when you try to blow the horns while door is open and buzzer is buzzing?
06A X66 711 57 57 M22 BU
x66 714
boomer632
Thanks Joe.. I get like an interupted kinda buzzer sound from relay with no horn. Both are on same relay so Im hoping that is a normal function
x66 714
I checked mine & the key buzzer & the horns will work together. On short toots, you hear both. Long horn blow, the horns drown out the key buzzer so I'm not 100% sure.....Joe
boomer632
David K
I've never even right about trying it out, but is it fixed?
boomer632
Seems to be in order. Like I said on phone Dave.. I would consider myself quite experienced now on taking apart and reassembling of turn signal switch. I came across an excellent document published by Saginaw that troubleshoots the key buzzer and horn mechanisms.
http://jimshea.corvettefaq.com/wp-content/uploads/2006/01/KeyBuzzerDiagnosis.doc
