1969 z/28 driveshaft
Started by asm69, July 14, 2006, 08:33:26 PM
My68SS
Another data point for the research - my car - 1968 L34 with THM400 has the yokes in-line
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
rich69rs
#16
Thanks for the input - another BB car (L34 396ci/350HP - SS only) with TH400 and in line yokes.
As appropriately referenced in a previous post - a limited amount of data to draw hard conclusions from - however, there seems to be a trend developing here.......
BB cars w/TH400 have driveshaft with in line yokes, everything else offset yokes.
I say again, what the h _ _ _, over?
Richard Thomas
1969 RS
Camaro Billy
I just replaced the U-joints on my '69 L-48 car.It has the offset driveshaft.It orig. came w/ TH-350 tranny, but has a date correct TH-400 from a big car.Not sure when it was swapped but an owner from 1982 says it was like that when he got it.It seems to work fine w/ the TH-400 and dosen't look like it was cut and shortened.
Billy
1969 RS/SS 350/300 Rallye Green . Black Vinyl Top
Mr12771
The TH350 trans is shorter then the TH400 trans by about 4". The shaft had to have been cut. Maybe it's a factory shaft for a Th400 with offset yokes. If it is the Th400 inline theory may have taken a step back.
RJ_RS_SS_350
I put a THM400 in my 67 I used to have and only had to put a 400 yoke on my PGlide driveshaft (and a new flexplate...and a different starter...and a crossmember...and a shifter). Didn't pay attention to if it was offset. That was about 20 years ago.  ;)
Dave69x33
RamAirDave,
RE: Picture of your drive shaft.
What was the build date of the car this came out of?  Was it a Norwood car? About how wide were the paint stripes, and the stripe location down from the approx centerline of the front yoke?
Camaro Billy
#21
Here are some shots of my driveshaft.Both ends and a casting mark from one end
Camaro Billy
#22
Here's a shot of the whole thing.Hard to see, but if you look close you can see the offset
Very old thread. This thread might be what started my interest in the topic.  Here is the result.
http://www.camaros.org/driveshaft.shtml
