front fender bolt finish
Started by rskev, February 18, 2011, 03:50:38 PM
rskev
Hello all! Just curious about the correct fender bolt finish for my 68' RS. Specifically, I'm referring to the bolts that hold the front fenders to the top of the radiator support. Are these supposed to be black phosphate or painted to match the body color? Thanks to anyone with advise!
tmodel66
None of the bolts are body color.
Daniel
rskev
Black Phosphate.... Lot's of information on this subject if you do some searches.
john302
Black phosphate is the correct plating. I also bead blast the bolts before plating.Also spray some type of oil on them before installing them to prevent rust . Put alittle strip caulk on the washer to prevent peeling the paint when tighting. John
