68 Fan Shroud Supports
Started by 68Y2RS/SS, August 27, 2026, 03:20:22 PM
68Y2RS/SS
Pictured is my current lower fan shroud on the passenger side. This obviously doesn't match the AIM drawing, which calls for the pictured bracket and clip. My buddy has a 67 that matches mine. Can someone enlighten me? If I'm supposed to use the bracket shown I don't see how it would attach with my current steel tab. Any help would be appreciated
Assuming you have an SS 350 car? What is the build month and week?
David K
I believe the fan shroud is 1 piece and does not have an upper and lower section. Is the radiator original as well as the shroud?
68Y2RS/SS
2nd week of July, and yes, SS 350
68Y2RS/SS
Quote from: David K on August 27, 2026, 05:54:10 PMI believe the fan shroud is 1 piece and does not have an upper and lower section. Is the radiator original as well as the shroud?
Yes, one piece and I believe both it and radiator are original to car
68Y2RS/SS
Quote from: bcmiller on August 27, 2026, 04:33:21 PMAssuming you have an SS 350 car? What is the build month and week?
David K
Does the radiator have the factory metal tag on it?
Your radiator might not be original.
Sauron327
The AT fittings and bracket are incorrect.
68Y2RS/SS
Quote from: David K on August 28, 2026, 11:07:24 AMDoes the radiator have the factory metal tag on it?
I'm guessing the tag is under this bracket that is welded to the radiator, done before my ownership.
68Y2RS/SS
Quote from: Sauron327 on August 28, 2026, 01:19:38 PMThe AT fittings and bracket are incorrect.
Quote from: 68Y2RS/SS on August 28, 2026, 01:48:05 PM
This is a friend's original out of his 67 RS. Looks like the same steel tab design as mine.
Quote from: bcmiller on August 28, 2026, 01:01:57 PMYour radiator might not be original.
Sauron327
Quote from: 68Y2RS/SS on August 28, 2026, 01:55:26 PM
Tags are visible. https://www.camaros.org/coolingsystems.shtml
