67 Camaro, replacing OEM fuel gauge with OEM tach
Started by idcipher, March 15, 2026, 03:20:47 PM
idcipher
My 1967 Camaro currently has the large fuel gauge (and right blinker indicator) in the dash.  So, it did not come with a tachometer.  I want to remove the big fuel gauge and put an OEM 67 tach (with right blinker indicator) in its place.  I do have a center floor console with gauges and plan to use that for the fuel gauge.
The question is, do I need anything more than a reproduction OEM tach (like this: https://www.classicindustries.com/product/6468911.html)?  More specifically, is the printed circuit board in the instrument cluster the same for dashes with the tach and dashes with the fuel gauge?  Or would I need to also buy the printed circuit board if I expect the tach wiring to be present at the connector to the instrument cluster?
Thanks for any help you can provide!
David K
Well, how will you know how much fuel is left?
You're going to need new wire harnesses (plural) for starters.....
