1967 Camaro 327/275 HP with 2 speed power glide correct starter number
Started by weave470, July 22, 2023, 03:49:46 PM
weave470
I am looking for the correct starter number for my May 9, 1967 Camaro. I have a couple of books that I have been reviewing. The Factory Assembly Instruction Manual shows UPC 6 1107496 with a revision of 5/31/66 to 1107320. With another revision 12/22/66 back to 1107496. The Service Manual shows 1107320. Legends Judging Manual shows 1107496 for small block cars in 1967.
TIA
Ken
David K
The service manual is a universal post factory replacement number.  What's your build date?
169INDY
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
weave470
The engine stamp is T0509MM.  May 9, 1967.  Cowl tag 05C so third week of May.
David K
weave470
weave470
Update
So I picked up a 1107496 Delco Remy starter the other day.  Upon inspection of the starter the bolt pattern does not line up with my engine like the 1107320 starter.
Swap the noses and you are good to go.  It was probably rebuilt at some point and the nose was installed.  Pretty common for reman companies.
weave470
In regards to the starter nose of the 1107496, were they cast iron or aluminum?
TIA
GMAD_Van Nuys
There is a starter with part number 1107496 for sale on eBay which appears to be original:
https://www.ebay.com/itm/403188733785
