Crossram and headers
Started by WaltZ, August 25, 2022, 08:56:12 AM
WaltZ
anyone running a crossram with headers on the street cruising with 302 and 30/30 cam.
jettting:
font carb p65s and s68s
rear carb p71s and s75s
any thoughts on this.
thanks in advance,
Walt
The 30/30 cam is not ideal for the cross ram set up, street or otherwise. I would recommend contacting Wayne Guinn through his FB group : https://www.facebook.com/groups/336597481642759
Quote from: WaltZ on August 25, 2022, 08:56:12 AM
jettting:
thanks in advance,
Walt
Hi Walt, we have a 69Z with Quinn certified cross-ram and carbs with repro headers BUT we have the original block stroked to 383 cu.in. and running a solid lifter roller. As previously stated normally not a good set up for the street and many things have to be done to make the set up street friendly.
David K
Making that thing "street friendly " is a task unto itself. Looks cool, sounds great, a monster in disguise.
crossboss
Cross-Rams in general are not for the faint of heart. They are not a bolt on and go set up. Regardless of the brand, a Cross-Ram has a design with a large plenum, with long runners. Terrible for off idle (lean stumble), vacuum issues, terrible low velocity and usually the power bands are from 3,000 RPMs and up. Stroking or a larger cid engine helps. In my opinion, the best bar none Cross-Rams were the Chrysler Hemi 'Rat-Roasters' That said, Chevy and Ford made their versions for specific engines/applications. Each of those have good and bad designs. I can give you advise on what I ran (Cross-Boss, and Inline carb on a Ford 302), however that won't help here. Getting back to the subject on hand, my best suggestion is to talk to guys who run them and get your tuning advice from them on what works and what does not work.
1968 Olds 442 W-30
BRG Z28
I currently have a 1968 Z28 with a all original crossram set up. The original carburetor were redone for street use. The car is extremely drivable and street friendly. If you went for a ride in the car you would not know it had a crossram under the hood, until I put my foot into it!
The key to making a crossram set up work; revamping the carburetors, headers and a transistor ignition.
Feel free to contact me if you would like some more in-depth information.
David K
I'd like to see some pictures of that!
BRG Z28
Original GM crossram, cowl plenum, headers, transistor ignition and J56 4 wheel disk brake.
BRG Z28
14,500 original miles, all original paint, factory stripe delete.
BRG Z28
Original blip top crossram intake with 4210 carbs. The only thing on the car that is reproduction is the positive battery cable. I am looking for a original one 😁
Again, the car starts right up, idles around 1200 rpm and drives like a new car.
crossboss
1968 Olds 442 W-30
169INDY
BRGZ
Great Post, Thanks for Posting. Boy I would like to see that Car!
Plug Shields W/ Kustom Headers, I will have to see if mine Fit  (ALL repops)
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
Coltdogg556
I started reading this post and I was going to say talk to Paul. I know he done it on 2 different 68 Z.  But as I was reading I see he done posted his beautiful car. It's a freaking tank. I know I am  going to set mine up as close as I can like Paul's 68Z.  Then only difference is mine will be getting a full restore job (way to far gone to even think about a survivor) then I will be doing a few re-pop parts like the headers,  linkage and some other hard to find parts. Then I will NOT be running the cowl plenum air cleaner.
As Paul said, the carbs need to be worked over for the streets. I would call Jarrod Wilkom with Allstate Carburetor.  I would also talk with Wayne Guinn with Guinn Engineering about the cam.
It also depends on what Holleys you are running.  You got the 4210's they are not the best to run, but then can be worked over good for street use.  Then you got the 3 digit date code 4295, the 4295 service carbs, and the 4295 re issued carbs. I read that the re issued are the best to run but getting harder to find.
Tom Cudeyro is also a well knowledgeable person when it comes to this as well.
Wish you the best if luck. Please keep us updated on what happens with it.
68 07C  Z28 UU, No Console,  No Tach with factory power steering. With 1968 Blip Top Cross Ram...
Replacing original Z28 intake/carb with a crossram generally means you want your Z28 (to look at).. rather than to drive...  but DRIVING a 'stockish' Z28 is so much fun!
