1969 turn signal lamps
Started by x66 714, July 23, 2018, 08:37:18 AM
x66 714
I looked at some turn signal lamps from a 1969 that were different from mine. These had a longer pigtail harness & no grommet where it would go to the fender wells. The valance these were attached to had a code of 42 & the fenders from the same car said 40. These parts have been in storage since 1970 or 1971. They're from a car that was made into a race car.
Did something get changed on real late 69s as far as t/s light go? Thank you, Joe
WorkinProgress
All front turn signals or parking lamps assemblies were the same through out the year. The only exception is the early lens with the trim ring and painted gray outside surface that goes around the lens.
A picture of what you are describing would be helpful.
        - Warren
169INDY
Quote from: WorkinProgress on July 23, 2018, 04:29:54 PM
        - Warren
Don't forget the Light monitor versions were part numbered differently, the housing and pigtail were different than ??% of the std assemblies.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
WorkinProgress
Quote from: 169INDY on July 23, 2018, 04:53:32 PM
        - Warren
Good point as I forgot about them.
                                                         - Warren
169INDY
One "OTHER" Idea could be (not likely) sometimes I hear that Olds 442 park lights are similar, Maybe I am out to lunch on this
68 Z28 M21 LOS
ZLP955
I have park/turn light housings with vigilite, as far as I can tell from a direct comparison, the pigtails and grommet are the same as on the non-vigilite housing, the fibre-optic wiring was run separately straight into the back of the metal housing.
Tim in Australia.
169INDY
Quote from: ZLP955 on July 23, 2018, 09:46:21 PM
The Grommet is different for the vigilite version. It has a more cone shape and a molded slot for the fiber optic. See the attached photo.
JIM
68 Z28 M21 LOS
ZLP955
Ok, didn't look that closely at the grommet itself Jim, good observation; but the main wiring is the same isn't it?
Tim in Australia.
ZLP955
Re-reading this thread jogged a memory about another thread, which I found here from back in 2013:
http://www.camaros.org/forum/index.php?topic=11349
Disregarding the grommet, is there a chance that the housings aren't actually originally Camaro parts, possibly thus explaining the different length of wiring?
Tim in Australia.
x66 714
Thanks for all the info. I'll get them in a couple of day & look them over real closely....Joe
169INDY
Quote from: ZLP955 on July 24, 2018, 05:14:28 AM
the SET of Fiber optic version I restored for a friend had same wiring (colors and function), connector, pins, sleeve & socket. Just the Stamped steel housing and the grommet appeared to be different than the STD version.
68 Z28 M21 LOS
Yes... 442 are the same EXACT HOUSING...
Just like the Pickup truck BED - lamp housing for 68-72 GM - C and K trucks is exactly the same as a 69 Camaro RALLYSPORT back up light housing and lens... EXACTLY.
