1968 Z28
Started by westonz28, July 17, 2016, 01:31:50 PM
westonz28
Picked up another 1968 Camaro this spring and though I should post the numbers for this site.
Vin is 124378l322365
Trim tag is,
12E                   U313
68-12437 LOS 21602
712             Y-Y
It has a BU 1213G 3.73 posi rear with leaf springs.
I have sent Kurt and Jerry M. lots of pictures of this Camaro and they have confirmed it to be one of the 7199 Z28's built is 1968. It still has evidence of the factory stripe on the rear and on the front panel. No motor or transmission. The 4 piston disc brakes are still there and the Muncie hole. Last time it was on the road was 1977. Still has original shocks on the rear and the correct exhaust is still there. There are a lot of pictures on Camaro Tech and a good discussion on this Camaro under "1968 Camaro". If I knew how to attach a link I would. I know most off us are on both sites but I though I should get these numbers to this site also. Thanks for all the help you guys do for us under educated car nuts.
67 RS L30/M20 numbers, 68 BB 396 12 bolt posi
68 Z28 project, 68 numbers 327/210 4 speed
69 LM1 turbo 350 12 bolt numbers,70 L65 350
68 Chevelle L30 3 on the tree, 68 El Camino BB
westonz28
Thank you bcmiller. Old guys are not great at computer stuff.
Being a LA car, if the gas tank is still in the car there may be a body broadcast sheet attached to the drivers side front corner.
