9N572683 - Z28 engine
Started by 1968RSZ28, August 10, 2015, 09:41:03 PM
Your 302cid/290hp Z/28 engine is on eBay...
Engine pad is stamped: V1226DZ
Partial VIN stamped by oil filter mounting boss: 19N572683 (My best guess from posted photo.)
Block casting number: 3932386
Block casting date: K 7 8
Seller id: steel4140
Seller location: Michigan City, IN
Seller contact info: Dan @ 219-873-1198
http://www.ebay.com/itm/121702803580?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
jdv69z
So what does it take to bend forged steel connecting rods? I'm assuming a race history? How do you do that without damaging the piston and/or crank?
Jimmy V.
Z10Mike
Blown head gasket and resultant hydro lock. Happened on a 396 I had as a kid.
jdv69z
Hi Mike, thanks for the insight. So when you had hydro lock, did it damage the pistons or crank as well? Seems like an aluminum piston would be damaged along with the rod. Maybe break the pin boss, or at least  cause cracks?
Jimmy V.
Kelley W King
I did it with a 327 365hp.  Only the rod was hurt. In fact the engine ran fine, just had a weird sound.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Z10Mike
jdv69z - Cracked one piston and bent the rod it was on.  Buckling of the rod beam was a classic "column load" yield failure.  Surprising the engine didn't grenade, but I wasn't twisting its tail when the failure occurred and I shut it down immediately.  Engine got rebuilt at that point and ran fine after. Rod might still be hanging in my dad's garage at the home place, lol...
jdv69z
Yes I remember seeing the results of rod failure in a 396 during drag racing. Big holes in the block, another cylinder with a frozen piston and a rod twisted like a pretzel. I'm not sure the heads were even salvageable. Intake destroyed. A literal explosion.
Jimmy V.
No sale 8-11-15...
Reserve not met = $5000.00
No sale 9-15-15...
jdv69z
Like an old 45 record re-playing over and over.
Jimmy V.
69 Zee
'69 Z/28 RS Cortez silver/black with endura bumper, U46 option
'69 Z/28, X77 Dusk Blue, white top, all orig, under restoration
'70 Plymouth Superbird, Limelight green, 45K miles
