1969 LM1 could this be one
Started by camaromikey, February 21, 2007, 11:42:22 PM
camaromikey
I have a 1969 camaro. Its VIN is 124379n56057. I've decoded its cowl tag. It was LeMans Blue with ivory standard interior and a parcemnt vinal top. It built in the second week of december.  It still has the orignnal rear end which a 12 bolt with a 2:56 ring gear and multi-leaf springs. Im guessing it was a 350 v-8 car because it has the duel fuel lines and it was a small block car. It was 3 speed auto with colume shift. It had four wheel non power drum brakes.  I just wanted to know is there a way to find out if it was one of these cars. I don't have a build sheet but everything I have points that way. Any help
cfar
Post the cowl tag numbers and that may help ID the car better and the rear numbers if you have them.
11C 1967 - Born on date estimated Nov 15th,1967 LA Plant
In Service Jan 18th, 1968  Hollywood CA
camaromikey
the tag reads: st6912437nor195236bdy
                    tr727  12b  71e  pnt
                             x44
Yes, the car is an LM1. No other model could have an X44 tag and 2 fuel lines.
Could you check the VIN, it's missing a digit?
Do you have the rear axle code?
Thanks!
camaromikey
sorry the vin is 124379n560573. i will post the rear axles codes later today. has this car ever been registered?
click
Kurt Im surprised that he found a 2:56 gearing in that 12bolt. Although I suppose someone could have changed out the gears. With the LM1 were you able to order such a highway gear for it? I thought only the Powerglides had that low of an option?
Click is Jim , central Minn.  Moderator at Team Camaro www.camaros.net
I've seen others with a 2.56. It appears that it was the economy ratio.
No, it was not in the database.
It has a 3 speed indicator on the column? Trans is gone?
Thanks!
camaromikey
Yes and the orignnal engine. It has a 75 350 in it now, but Im building a 327 for it out of another 69 camaro. It will take few days for me to get the axles codes. What can i do to get it registered.
camaromikey
i got two of the rear axle numbers. i have the casting code which reads L68. i looked at the chart on CRG that was just posted but mine has only those 2 numbers and that letter. Also I have casting number which is 3894860NF which i already know its a 12 bolt. Thrusday I'll post the axle code because i have to pull the tires off. I know it starts with a P
huggerorange
Congratulations. It sounds like a really cool car. I have heard of LM1s, but what exactly were they?
Don from Midland, TX
Quote from: huggerorange on March 14, 2007, 01:57:38 PM
Don -
Here's your answer:
http://www.camaros.org/lm1.shtml
camaromikey
Its going to be a really cool car some day. It's just a daily drive for now. It needs to be restored but Im doing what I can till that time comes. It was my first car so its really specail to me
camaromikey
the axles code is PY1101G now it also had a marking behind the G that looked like another 1, but im not sure if thats part of the number. So is it possible for it to be the right rear end.
camaromikey -
Yes, it appears to be the correct rear axle for your car.  Yes, the 1 after the G is part of the axle code and is interpreted as "first shift".  PY1101G1 decodes as 2.56:1 axle ratio, non-posi, 12 bolt rear axle assembled on November 1, 1968 by the Detroit Gear & Axle Plant, first shift.  The date also would be correct for a 12B built car.  Congratulations!
