CRG Discussion Forum
Welcome, Guest. Please login or register.
Did you miss your activation email?
May 21, 2013, 08:37:03 PM
Search:     Advanced search
Forum registration problems: Make sure you enter your email correctly and you check your spam box first. *Then* email KurtS2@gmail for help.
82092 Posts in 10493 Topics by 4346 Members
Latest Member: SCOTT96X
* Home Help Search Login Register
+  CRG Discussion Forum
|-+  Camaro Research Group Discussion
| |-+  Restoration
| | |-+  69 Carpet Configuration-Front Seats
« previous next »
Pages: [1] 2 3  All Print
Author Topic: 69 Carpet Configuration-Front Seats  (Read 2409 times)
Mac B
Member
View Profile Email
« on: July 18, 2012, 06:38:02 AM »
Does anyone have photos or suggestions for proper install of front seats in relation to stock carpet.  I understand that the seats are supposed to be UNDER the carpet.  Mine are currently installed over the carpet.  Since I have them out for cleaning and under dash work I want to reinstall them correctly. This will install cutting perfectly good carpet so I do not want to make mistakes.   Thanks for your help.
Logged
CRG Member
View Profile Email
« Reply #1 on: July 18, 2012, 12:31:33 PM »
On my untouched original 02D Norwood '69, the seat tracks are bolted directly to the floor at both ends; the rear carpet covers the rear bolts, and the rear bound edge of the front carpet covers the front bolts.
Logged
Mac B
Member
View Profile Email
« Reply #2 on: July 18, 2012, 12:40:28 PM »
Thanks John, so can you tell if there is a slit from bolt hole to bolt hole?
Logged
CRG Member
View Profile Email
« Reply #3 on: July 19, 2012, 09:49:10 AM »
Yes, there are slits in the rear carpet around the rear of the seat tracks.
Logged
69pace
Member
View Profile
« Reply #4 on: July 20, 2012, 02:21:48 AM »
Any pictures?
Logged
CRG Member
View Profile Email
« Reply #5 on: July 20, 2012, 11:09:20 AM »
<<Any pictures?>>
Here's a shot of the rear of the passenger side inboard seat track - you can see the flap at the rear that covers the bolt. The slits for both tracks run all the way to the front edge of the rear carpet, and that front edge is covered by the rear edge of the front carpet, below the front of the seat.
Logged
69pace
Member
View Profile
« Reply #6 on: July 20, 2012, 04:36:42 PM »
Ah Thanks John now I see. So the flap is also folded under the seat between the rails.
Logged
Mac B
Member
View Profile Email
« Reply #7 on: July 20, 2012, 05:07:33 PM »
Thanks John, very helpful.
Logged
CRG Member
View Profile Email
« Reply #8 on: July 21, 2012, 09:17:06 AM »
Yup - the wide center flap (between the inboard and outboard seat tracks) and the narrow outboard flaps run all the way forward.
Logged
Hero Member
View Profile WWW
« Reply #9 on: December 22, 2012, 08:03:51 AM »
John,
Is where the leg tucks in just a 90 deg cut then running forward? Or does the long cut running along the track extend back as far as the short leg towards the rear where it would create an actual flap which could fold back vs a corner which could be held back to install the bolt?
Does this make sense?
Logged
Check out the Black 69 RS/Z28 45k mile Survivor and the Lemans Blue 69 Z 10D frame off...
https://picasaweb.google.com/112392262205377424364/1969_Z28_Restoration
NoYenko
Member
View Profile
« Reply #10 on: December 22, 2012, 09:45:15 AM »
John great picture but I am still puzzled by the cut descriptions. I drew up a picture to help me. Can you tell me if that looks correct. Merry Christmas to all. George
Logged
CRG Member
View Profile Email
« Reply #11 on: December 22, 2012, 11:52:40 AM »
The slits run the full length of the tracks, as shown in reply #10. Two photos below show the front of the inboard passenger side track where it bolts to the floor. First one is with the carpet in normal position (rear edge of front carpet covering the bolt), second one has the rear edge of the front carpet pulled forward to expose the front edge of the rear carpet adjacent to the track.
Logged
Barefoot Dave
Member
View Profile WWW Email
« Reply #12 on: December 22, 2012, 04:39:33 PM »
The pics here may help too.
http://fototime.com/ftweb/bin/ft.dll/detailfs?userid={D08B98E5-90DE-49D3-B97D-30DAB312653F}&ndx=0&slideshow=0&AlbumId={98167C98-41AD-44FB-AD79-A14AF4CE8569}&GroupId=&screenheight=768
Logged
Dave Miller
Fairfax VA
69 SB Z-11
69 BB Z-10
www.barefootdave.com
Hero Member
View Profile WWW
« Reply #13 on: December 22, 2012, 07:20:25 PM »
Exactly like I had pictured in my mind... or does the long cut continue down and terminate at the same point toward the rear like the short inner cut?
Logged
NoYenko
Member
View Profile
« Reply #14 on: December 22, 2012, 11:29:11 PM »
Guys those actual photos show a clearer idea on the carpet cuts, but I thought I would correct my drawing to match John's description. George
Logged
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Page created in 0.087 seconds with 17 queries.
