Author Topic: tag on coil spring.  (Read 10161 times)
BillOhio
    • photobucket
tag on coil spring.
« on: July 07, 2012, 03:40:02 AM »
While cleaning my recent purchase, I found the tag still around the coil spring.
It was really  nice. I was wondering, should I take it off and put it in a scrapebook?
1968 RS 327 4 speed
rich69rs
  • LF7/M35/Z22/Z87
Re: tag on coil spring.
« Reply #1 on: July 09, 2012, 08:31:40 PM »
That's what I did with mine.
Richard Thomas
1969 RS
jacmac
« Reply #2 on: July 10, 2012, 11:18:23 PM »
Thats what I did to all my decals,tags ect.Save them!
69 Z10,69 ss396Chevelle, 71 Corvette
« Reply #3 on: July 10, 2012, 11:49:02 PM »
How does it compare to repro stickers? Can you post a pic?
thanks
« Reply #4 on: July 11, 2012, 12:12:32 AM »
I notice many restorations have the coil spring tags right there where everybody can see them. On my last '69 Z they were on the ends of the springs, out of sight inside the frame. I have never seen a coil spring tag in a vintage chassis photo.
« Reply #5 on: July 11, 2012, 12:54:44 AM »
That's how it is on my original 67...the tag is just up inside the chassis and out of sight unless you look up into that cavity.
rat pack
« Reply #6 on: July 11, 2012, 02:51:13 PM »
Spring tag from the unrestored 68 at the Camaro Nat's this year. I got this picture while it was on the lift..............RatPack.............
BillOhio
    • photobucket
« Reply #7 on: July 12, 2012, 12:42:31 PM »
Mine is toward the bottom, maybe upside down lol .
I didnt see one on the drivers side and when trying to clean it a little more pulled this one off.
1968 RS 327 4 speed
Steve Shauger
    • Vintage Certification
« Reply #8 on: July 12, 2012, 01:41:31 PM »
On unrestored cars I have found that for the most part the spring tags are visible. They may be dirty, deteriorate or have only a portion remaining.  To Williams point, I'm sure most restorers install the tag after the spring is installed and place the tags where the spring coils are accessible and easy to reach.
Steve Shauger
jdv69z
  • 69 RS Z/28 52E
« Reply #9 on: July 12, 2012, 03:08:40 PM »
Mine are up inside the frame.
Jimmy V.
Jimmy V.
jeff68
« Reply #10 on: July 12, 2012, 04:39:30 PM »
I found my original tags toward the tops of the springs as well.
MO
« Reply #11 on: July 13, 2012, 01:44:58 AM »
It makes sense that the tags were on the springs before installation, which is how the line identified them. And whomever was responsible for installing the tags put them on the top ring. Why reach down further than needed?
68Zproject
« Reply #12 on: July 13, 2012, 05:07:39 PM »
Mine were on the bottom.  Well, the one I found anyway.  I thought it was a piece of junk caught in all the grease and dirt.
68Z28
