Author Topic: Two piece brake rotor replacement.  (Read 27195 times)
Re: Two piece brake rotor replacement.
« Reply #30 on: July 04, 2012, 06:29:55 AM »
I've driven my daily driver car and many others with drums and rotors turned way past the specs and never had a problem.  If you're driving so close to the edge that a few thousanths of an inch mean life or death, I'd take a bus.
DAVEN1256
« Reply #31 on: July 04, 2012, 04:15:16 PM »
I've driven my daily driver car and many others with drums and rotors turned way past the specs and never had a problem.  If you're driving so close to the edge that a few thousandths of an inch mean life or death, I'd take a bus.
I have no idea how significant those few thousandths are. Some feel it could be dangerous and other don't...... I would think, however, that the manufactureres build some extra margin into those minimum specs just to cover themselves............How do you get yours turned past the minimum? Do you take them to a shop and they do it regardless of the fact that they are going past the minimum?
Petes L48
« Reply #32 on: July 07, 2012, 09:59:00 PM »
I pulled out my originals, one hub had green paint at the outer end.  This one was missing the rotor when I got the car.  My other assembly did not have any paint markings, and the rotor was not drilled/balanced.  Early 67 LOS
vtfb68
« Reply #33 on: July 08, 2012, 01:38:57 AM »
Pete,
Thats the same as mine, late 68 LA. Might be an inspection or ID of some sort. Anybody know?
We can be perty sure they are factory originals.
   VT
68 08E LA RS Y2 749 L30 M35
