CRG Discussion Forum
Welcome, Guest. Please login or register.
Did you miss your activation email?
June 18, 2013, 12:58:32 AM
Search:     Advanced search
Forum registration problems: Make sure you enter your email correctly and you check your spam box first. *Then* email KurtS2@gmail for help.
83110 Posts in 10587 Topics by 4403 Members
Latest Member: cwylie
* Home Help Search Login Register
+  CRG Discussion Forum
|-+  Camaro Research Group Discussion
| |-+  Restoration
| | |-+  68 Defroster Vent - Seals?
« previous next »
Pages: [1] Print
Author Topic: 68 Defroster Vent - Seals?  (Read 608 times)
jeff68
Member
View Profile
« on: March 03, 2012, 09:08:49 AM »
Was there any type of foam seal used between the Y-shaped defroster duct and the openings in the metal dash panel?
Logged
68 L30 / M20 Convertible
Ash Gold
CRG Member
View Profile Email
« Reply #1 on: March 03, 2012, 10:28:39 AM »
Nope - no seals.
Logged
jeff68
Member
View Profile
« Reply #2 on: March 03, 2012, 11:55:31 AM »
Thanks John.
Logged
Ash Gold
jeff68
Member
View Profile
« Reply #3 on: June 29, 2012, 04:13:57 PM »
New info:
I went back and looked at the pictures I took when my upper dash was removed, and there were definitely foam seals between defroster duct and the metal dash top.  They were attached to the defroster duct, and were a single strip at the back edge of each side (they didn't go all the way around the openings).
I was also looking at the 69 AIM online today and noticed that it calls out for seals between the defroster duct and the metal upper dash.  They are different for each side, which seems strange.
So, is anybody installing these seals?  If so, what are you using?
Logged
Ash Gold
CRG Member
View Profile Email
« Reply #4 on: June 30, 2012, 10:08:01 AM »
Nope - no seals.
Oops - my mistake - I mis-read the original post; thought the question was about seals between the defroster duct and the top of the heater case. As noted, there WERE foam seals between the top legs of the duct and the underside of the steel instrument panel.
Logged
jeff68
Member
View Profile
« Reply #5 on: June 30, 2012, 10:37:31 AM »
No problem.
Any suggestions on what to use?  The remnants of the original stuff (which is now basically turning to dust) seems to be a very lightweight open-cell foam.  I guess I can see what the local hardware store or McMaster Carr has.
Logged
Ash Gold
tmodel66
Hero Member
View Profile Email
« Reply #6 on: June 30, 2012, 10:54:43 AM »
I used strip foam that you use to seal a door  on a house. You can get it 1/4" wide and sticky on one side. Got at the local hardware store.
Logged
scoop
Member
View Profile
« Reply #7 on: July 05, 2012, 08:15:30 PM »
Bob Harris at Camaro Specialties sells a complete kit with all the seals necessary to install the heater core, heater box, and the top defroster seals.
Logged
Pages: [1] Print
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Page created in 0.091 seconds with 17 queries.
