May 21, 2013, 09:16:38 AM
Search:     Advanced search
82063 Posts in 10493 Topics by 4345 Members
Latest Member: bsharp2
+  CRG Discussion Forum
| |-+  Restoration
| | |-+  Rear sub frame bolt tape
« previous next »
Pages: [1] 2  All Print
Author Topic: Rear sub frame bolt tape  (Read 1949 times)
john302
Member
View Profile Email
« on: April 17, 2011, 07:35:01 PM »
Does anyone know what the width of the tape that covers the rear sub frame hole in floor pan?Any ideas what to use for tape? painted masking tape? black gorilla tape? thanks John Huh
Logged
BlackoutSteve
Member
138139883
View Profile Email
« Reply #1 on: April 18, 2011, 05:17:09 AM »
Got more info on the hole you are referring to? Pics?
Logged
Restoring my RHD 69 Jane in Melbourne, Australia.
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
Hero Member
View Profile Email
« Reply #2 on: April 18, 2011, 06:28:25 AM »
This is what John is asking about and Quanta sells marking kits which have the tape or you can purchase it by itself. Others like heartbeat sell it also I'm pretty sure. JohnZ wrote some time back that he thought the tape was used to tape off the #3 hole for the water test..... I have the tape and will report back the size, etc...
Logged
68 Z28 NOR 01B
69 Z28 NOR 07A
john302
Member
View Profile Email
« Reply #3 on: April 18, 2011, 07:28:10 AM »
I think the tape covers the holes in the floor pan .That picture does not look correct. The reason they used the tape is for the water test???thanks John
Logged
CRG Member
View Profile Email
« Reply #4 on: April 18, 2011, 11:26:43 AM »
Fisher Body used a piece of tape over both of the #3 body mount holes in the floor pan to seal them for their water test, before the body was delivered to the Chevrolet side of the plant; I don't recall what type of tape they used.
Logged
68Zproject
Hero Member
View Profile Email
« Reply #5 on: April 18, 2011, 05:20:11 PM »
Are you talking about where the sub frame bolts go into the body?
Logged
68Z28
john302
Member
View Profile Email
« Reply #6 on: April 18, 2011, 08:00:47 PM »
Hello, yes the rear hole in the floor pan ,below the seat. thanks John
Logged
Hero Member
View Profile Email
« Reply #7 on: April 18, 2011, 09:24:14 PM »
The tape is 3/4" wide and is very different in black texture. Not like any other tape I could tell you to go get. I mentioned in my post what John had mentioned some time back concerning the tape being used for covering the hole for the water test. The picture is of what comes in the Quanta kit is is listed as "Technical Bullentin #69".
Logged
68 Z28 NOR 01B
69 Z28 NOR 07A
m22mike
Member
View Profile
« Reply #8 on: April 19, 2011, 07:29:19 PM »
Here is the tape John Z is talking about and was to cover the hole for water test. To my knowledge 1st. gen Camaros did not have any mounts taped to the frame. Note the sticky side is up. I think it is 2" and the OE's I have seen are black. I have used masking tape and rattle canned it with black lacquer with good results. AMK carries the black tape. I even scrounged up a roll at Carlise last year.
A 67
A 69
Logged
X66 L78 M22 4.10 Deluxe Threads, PNT 10/10, Red Hockey stripe
68Zproject
Hero Member
View Profile Email
« Reply #9 on: April 19, 2011, 08:00:56 PM »
Mine had tape that went around like it held them to the frame for placing the body on when I took the originals off.
Logged
68Z28
m22mike
Member
View Profile
« Reply #10 on: April 19, 2011, 10:04:58 PM »
Any chance it had both ?
Logged
CRG Member
View Profile Email
« Reply #11 on: April 20, 2011, 01:18:57 PM »
That's a distinct possibility - Corvettes had all eight cushions taped to the frame, and so did some passenger cars; if problems were encountered with cushions coming off at Body Drop, Production would start taping them until the issue was resolved - it was an ugly repair, or a line-stop issue.
Logged
68Zproject
Hero Member
View Profile Email
« Reply #12 on: April 20, 2011, 07:11:03 PM »
I don't recall any tape on my plugs, but I do have my originals in a box and remember the tape around the sides when I replaced them.
Logged
68Z28
Charley
Member
View Profile WWW Email
« Reply #13 on: April 21, 2011, 09:54:23 AM »
It looks like Gaffers tape. I have a roll I will dig out and get a pic.
Logged
BlackoutSteve
Member
138139883
View Profile Email
« Reply #14 on: April 21, 2011, 09:09:16 PM »
I see there is a pic there labelled as a 69.. (Thanks M22Mike) ..but the 69 AIM (UPC 1-D1) makes no mention of the tape in it's illustration or components list.
Are we sure it's also a 69 detail?  Smiley
Also Charley, Isn't Gaffer tape the same woven cloth tape that is often used to tape down audio cables temporarily at events and such? (I think originally produced by Nashua)
The tape in the pics doesn't appear to be that same tape. It looks more like a very wide version of the same paper-type tape used to retain some of the single wires to wiring looms in the car.
Logged
« previous next »
Jump to:
Page created in 0.082 seconds with 18 queries.
