Author Topic: Befuddled - Alternator not lining up with other pulleys  (Read 9331 times)
my124677n
« on: January 28, 2011, 11:30:04 PM »
I have raised this issue once befor on the forum, but I can not get my alternator pulley to line up with the water pump & harmonic balancer pulleys on my 1967 small block 327. The latter two are fine, but the alternator pulley is about 1/2 to 3/4 inch behind the other two.  I purchased a new upper bracket and still no luck.  Could the alternator be incorrect for this year block? I have attached two pictures.  Any one out there see anything???
« Last Edit: January 29, 2011, 12:23:17 AM by my124677n »
my124677n
Re: Befuddled - Alternator not lining up - more pix
« Reply #1 on: January 29, 2011, 12:27:16 AM »
Here are a few more pictures with the upper bracket in place.
BlackoutSteve
Re: Befuddled - Alternator not lining up with other pulleys
« Reply #2 on: January 29, 2011, 03:20:08 AM »
It's not uncommon to have to shim the pulley & fan forward with e few washers.
Also, the deep groove alt pulley (I think) has a little more offset that may require no or fewer washers/shims, just in case you were thinking of using one.
« Reply #3 on: January 31, 2011, 09:31:58 AM »
The stock lower bracket locates the alternator, the upper bracket has nothing to do with it. I had to shim my pulley an 1/8" and I run a Delco. The upper ear belongs behind the upper bracket.
« Last Edit: January 31, 2011, 10:43:33 AM by Sauron327 »
x77-69z28
« Reply #4 on: February 02, 2011, 12:32:26 AM »
not on 67 it doesnt
« Reply #5 on: February 02, 2011, 01:40:22 AM »
not on 67 it doesnt
My mistake. I see that now. I have been running a '69 snowflake since '84 and don't run the stock upper.
my124677n
« Reply #6 on: February 02, 2011, 04:45:35 AM »
I talked to an alternator shop and they are just going to put a double pulley on the alternator.  I will use the outside groove and it should pretty much line up with the other two pulleys.  That should hopefully get rid of the squeak.
« Reply #7 on: February 02, 2011, 12:22:32 PM »
Something is askew. You should not have to do that if the components are correct.
