Author Topic: Donor cars for a Tremec 5 speed tranny?  (Read 20135 times)
sdkar
« on: May 17, 2006, 12:21:56 PM »
I would like to try and get a 5-speed from a donor car.  I hear all this info about WC and NWC tremec transmissions.  What does that mean.  Also, what donor cars should I look for to get a good 5 speed tremec manual transmission that will hold up with a 500hp motor?
Thanks.
Re: Donor cars for a Tremec 5 speed tranny?
« Reply #1 on: May 17, 2006, 04:26:09 PM »
None of the factory-installed Tremecs (except the T56 in the Viper) will survive behind a 500hp motor; you'll need a T56 or a TKO600 like Keisler Engineering offers.
McKenzieDave
« Reply #2 on: May 17, 2006, 05:42:31 PM »
Check this out!  www.5speedtransmissions.com/index.html  Click on the 5 speed section on the left and select GM TKO package.  By the time you break a couple of Muncies this will seem not so unreasonable.  Also study the comparison to the Richmonds.  I've personally seen a couple of these things in action.  That TKO 600 is impressive and also has a couple of options for overdrive ratio.  Dave
pdq67
« Reply #3 on: November 27, 2009, 08:55:45 PM »
Jamie Passion is creating a new Muncie 5-speed so please contact them.
And there is a new MOPAR A833 5-speed out now that you might find interesting.
And A833's came stock in some of our mid '80's trucks.
I want to say that these are both 800 T trannys!
pdq67
