May 22, 2013, 12:49:13 AM
Search:     Advanced search
82109 Posts in 10493 Topics by 4346 Members
Latest Member: SCOTT96X
+  CRG Discussion Forum
| |-+  Decoding/Numbers
| | |-+  68 Camaro Horn
« previous next »
Pages: [1] Print
Author Topic: 68 Camaro Horn  (Read 1245 times)
Larry
Member
View Profile WWW Email
« on: April 23, 2010, 02:41:26 PM »
I'm trying to find the part number for a 1968 Camaro horn. I have a Delco Remy horn with part number 9001121 and the letter H in a circle. Is this the correct one for a 1968 Camaro?
Logged
Ed Bertrand
CRG Member
« Reply #1 on: April 23, 2010, 03:02:49 PM »
1968 Camaro horns are 9000477 (low note) and 9000214 (high note). I don't know what a 9001121 fits, but going by the number, it appears to be a 70's horn.
Logged
Ed Bertrand
CRG Member
Larry
Member
« Reply #2 on: April 23, 2010, 03:39:05 PM »
Thanks Ed!
Logged
Larry
Member
« Reply #3 on: April 24, 2010, 09:35:20 AM »
One more question. Did they come with 1 horn or 2?
Logged
CRG Member
View Profile Email
« Reply #4 on: April 24, 2010, 09:40:22 AM »
They had two horns - low note and high note, as shown in the Assembly Manual.
Logged
Larry
Member
« Reply #5 on: April 24, 2010, 01:17:55 PM »
Thanks JohnZ. I thought there were 2, but I couldn't find in my Assembly Manual.
Logged
Ed Bertrand
CRG Member
« Reply #6 on: April 24, 2010, 05:53:10 PM »
Larry, the horns are in the electrical section (UPC 12). For 1968 it's sheet A8. IF you have a Rally Sport car, you also need to look at UPC Z22 (Page A13) for the different mounting location.
Logged
Ed Bertrand
CRG Member
Larry
Member
« Reply #7 on: April 24, 2010, 07:01:16 PM »
Thanks alot, Ed. I do have a RS so I appreciate all the great information.
Logged
tom
Hero Member
« Reply #8 on: April 24, 2010, 10:42:32 PM »
Many GM cars of the era used the same horns with different brackets. The numbers above, I beleive apply to the assembled unit with the brackets. If you still have the original brackets, you may be able to replace just the actual horns. This would give you more options lookiing for original horns.
Logged
69 X11 Z21 L14 glide
looking for a 69 export model (KPH) speedo
Pages: [1] Print
« previous next »
Jump to:
Page created in 0.099 seconds with 17 queries.
