Author Topic: 68 Camaro Horn  (Read 9672 times)
Larry
    • 1968 Camaro Z 28 Rally Sport
68 Camaro Horn
« on: April 23, 2010, 07:41:26 PM »
I'm trying to find the part number for a 1968 Camaro horn. I have a Delco Remy horn with part number 9001121 and the letter H in a circle. Is this the correct one for a 1968 Camaro?
Re: 68 Camaro Horn
« Reply #1 on: April 23, 2010, 08:02:49 PM »
1968 Camaro horns are 9000477 (low note) and 9000214 (high note). I don't know what a 9001121 fits, but going by the number, it appears to be a 70's horn.
Larry
Re: 68 Camaro Horn
« Reply #2 on: April 23, 2010, 08:39:05 PM »
Thanks Ed!
Larry
Re: 68 Camaro Horn
« Reply #3 on: April 24, 2010, 02:35:20 PM »
One more question. Did they come with 1 horn or 2?
Re: 68 Camaro Horn
« Reply #4 on: April 24, 2010, 02:40:22 PM »
They had two horns - low note and high note, as shown in the Assembly Manual.
Larry
Re: 68 Camaro Horn
« Reply #5 on: April 24, 2010, 06:17:55 PM »
Thanks JohnZ. I thought there were 2, but I couldn't find in my Assembly Manual.
Re: 68 Camaro Horn
« Reply #6 on: April 24, 2010, 10:53:10 PM »
Larry, the horns are in the electrical section (UPC 12). For 1968 it's sheet A8. IF you have a Rally Sport car, you also need to look at UPC Z22 (Page A13) for the different mounting location.
Larry
Re: 68 Camaro Horn
« Reply #7 on: April 25, 2010, 12:01:16 AM »
Thanks alot, Ed. I do have a RS so I appreciate all the great information.
tom
    • Discount Internet Services
Re: 68 Camaro Horn
« Reply #8 on: April 25, 2010, 03:42:32 AM »
Many GM cars of the era used the same horns with different brackets. The numbers above, I beleive apply to the assembled unit with the brackets. If you still have the original brackets, you may be able to replace just the actual horns. This would give you more options lookiing for original horns.
69 X11 Z21 L14 glide
o
