Author Topic: 1968 327 275hp. non smog air cleaner housing  (Read 27257 times)
rick-68
« on: March 12, 2006, 03:07:44 PM »
I have a 68 rs . Can,t seem to find the correct air filter housing assembly for non smog and with auto trans.. I think it has a vent elbow for right side v/cover and no heat stove and thermo valve.  I NEED YOUR HELP  PLEASE!!!!
ccargo
Re: 1968 327 275hp. non smog air cleaner housing
« Reply #1 on: March 12, 2006, 03:37:28 PM »
It should have a left side manifold heat stove with elbow pipe to the air cleaner.
67 O-1 O4A L35 Convertible, Indy Zone IPC
« Reply #2 on: March 12, 2006, 05:20:02 PM »
Left side? Left = driver's side, Right = passenger side.
rick-68
« Reply #3 on: March 12, 2006, 10:36:43 PM »
thanks johnZ,, Do you know where I may find one of these.. In any condition???  Thanks Rick  PS, In the assembly manual they list two air housing #s  They both show no heat stoves?  The #s are--6983655 & 6484221.. my car is LA built  #1295TH built First week of sept w/powerglide
« Last Edit: March 12, 2006, 10:56:09 PM by rick »
JohnKY
« Reply #4 on: March 12, 2006, 10:59:08 PM »
Heat stove was on the left (drivers) side in 68. Moved to the right side in 69.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #5 on: March 13, 2006, 07:23:53 PM »
In the course of trying to find the correct air cleaner for my '69RS base coupe, I collected a couple of others, one may be a '68.  I have at least 3 dfferent variants hanging on the wall in the garage.  If you can e-mail me with the details, I'll compare to what I have and can send you pics as well.
Let me know.
Richard
Richard Thomas
1969 RS
ccargo
« Reply #6 on: March 13, 2006, 09:03:34 PM »
This isn't the best photo of the setup but does show the 327/275hp air cleaner and stove pipe. The manifold stove and the stove pipe are the tough ones to find.
rick-68
« Reply #7 on: March 14, 2006, 12:04:33 AM »
It looks like the one that CCARGO HAS.  Call me any time after 5:30 pm   my # 440-266-0554 ... I 'm interested ...   THANKS    RICK.................
Let me know.
Richard
rich69rs
  • LF7/M35/Z22/Z87
« Reply #8 on: March 14, 2006, 12:41:25 AM »
Will check tonight and get back to you tomorrow.
Richard
Richard Thomas
1969 RS
rich69rs
  • LF7/M35/Z22/Z87
« Reply #9 on: March 14, 2006, 05:47:48 PM »
Air cleaner that I have that I believe is a '68 is smaller in heighth than the one you have.  I believe it is for the base 210 Hp configuration which would have had a Rochester 2BBl with 1-1/4" throttle plates.
Sorry I wasn't able to help.
Richard
Richard Thomas
1969 RS
rick-68
« Reply #10 on: March 14, 2006, 11:18:57 PM »
Hay,, thanks for the effort Rich,, I'll have to keep looking for that NEEDLE IN A HAY STACK..........Thanks Rick...
Richard
« Last Edit: April 08, 2006, 02:13:20 AM by rick-68 »
rick-68
« Reply #11 on: March 14, 2006, 11:32:43 PM »
If anyone out there knows anybody that has such a filter housing. Please contact here or e-mail at rmmcsween@sbcglobal.net or Call  (440)266-0554  Ohio.......    Thanks ......
« Last Edit: April 08, 2006, 02:14:50 AM by rick-68 »
KevinK
    • Hudson Valley Camaro
« Reply #12 on: March 23, 2006, 03:14:33 PM »
  Rick,
   I don't have a spare, ...but am following this thread since I also have a '68 327/275 auto.
   My question however, ...wouldn't the air filter housing be the same (with auto trans) for a 350(SS) and the 327/275, ...since both had Q-jet carbs? (with the exception of the chrome lid for an SS)?
ccargo
« Reply #13 on: March 23, 2006, 04:25:51 PM »
That's correct, the L48 and L30 are very similar in many regards....just a little more bling  ;)
ccargo
« Reply #14 on: March 23, 2006, 04:45:01 PM »
I might as well add a shot of my 68 L35 with A/C to cover the bases. It gets alot more crowded and complicated with a BB, A/C, and smog  ::)
