Author Topic: 1969 Z/28 5 leaf rear springs  (Read 8192 times)
sam
« on: September 20, 2008, 04:28:07 PM »
If a 69 Z/28 came with the optional 5 leaf rear springs would they still have the Z/28 yellow (BM) code tag or would they have the BB 5 leaf code tag which I believe is a yellow (BK) code tag?  Thanks,  Sam
Re: 1969 Z/28 5 leaf rear springs
« Reply #1 on: September 21, 2008, 03:47:14 AM »
Any spring would have the tag that matches that spring part #.
sam
« Reply #2 on: September 21, 2008, 05:11:07 PM »
Thanks Kurt. I assume it gets the (BK) tag.  Sam
« Reply #3 on: September 22, 2008, 12:22:37 AM »
I should add I've never seen a 69 Z with 5 leafs. There was no spring option for Z's.
Not to say they couldn't exist, but the service spring tables clearly show only one part for Z's, BM.
http://www.camaros.org/suspen.shtml#spring
This is a good question for Jerry. :)
GaryL
  • Marilyn and me
« Reply #4 on: September 22, 2008, 01:22:38 AM »
Kurt, what was the difference between the three front springs for Z/28?  The rate, free length?
Gary
« Reply #5 on: September 22, 2008, 04:16:17 PM »
It must be rate. The AMA submission shows the same design height (height at design load) for standard V-8 and Z/28 springs, but the Z/28 springs have a shorter overall (unwound) coil length and larger bar diameter. Free length of a coil spring is essentially meaningless - coil springs are rated at their design load, not at free length.
