Author Topic: new guy hi  (Read 18891 times)
COflyer67
new guy hi
« on: June 20, 2008, 10:16:30 PM »
Hi guys-  Just checking in for the first time.  Have an original ’67 RS convertible (owned since new). VIN 124677N138016. Cowl tag 11C  E  ST  67-12467  NOR  37199  TR  760-Z  F-1   D  2LG  3L.  327/275hp, 4speed (Saginaw with Muncie shifter).  Front disc/rear drum brakes.  Power top.  Have original order sheet (Nov ’66), protect-o-plate, & manuals. 10 bolt rear with no radius bar nor attach fittings.  Early style qtr panels (telephone indents).  No holes on inside of front frame horn.  Trunk lid inside has 1 diagonal opening on left side/no holes.  Has 3 openings on right side for camaro emblem attach.  cheers
CanCam68
Re: new guy hi
« Reply #1 on: June 22, 2008, 04:37:13 AM »
Welcome to this site, COflyer67.  Guess I'm it for the welcoming committee?...Been on here for a week or so, and haven't heard from a soul, myself.  So, thought to take the time to say Hi!
I too have a vert, with much the same set up, but a '68 and an auto, with three on the tree... was a special order...which I don't intend to change.
Take care,
CanCam
69houdini
  • 69 SS X55 Butternut Vert / 68 Z28 Rally Green
Re: new guy hi
« Reply #2 on: June 22, 2008, 09:08:51 PM »
Hi again and welcome, I too have a vert however it's a 69. Lot's of great talk and help on this site. Sometimes pretty quiet then it seems to all break loose. Hang in there and you'll get what you need. 69 Houdini
philip
  • hello from FRANCE
Re: new guy hi
« Reply #3 on: June 23, 2008, 08:38:24 AM »
welcome aboard !
i own a car very similar yours, it's a export model cause i'm living in france.
just like you it's a rare L30M20 convertible with RS and deluxe interior.
10 bolts with no radius rod and mine is a 11B.
convertible 1967.12467
RPO: A02-A31-A67-B37-B93-C06-D55-F41-G80-J50-J52-K02-L30 -M20-N33-N40-N61-U17-U18-U25-26-27-28-29-V31-V32 Z21-Z22-Z87
COflyer67
Re: new guy hi
« Reply #4 on: June 23, 2008, 04:37:05 PM »
hi guys- thanks for welcome- COflyer67
Re: new guy hi
« Reply #5 on: June 24, 2008, 03:18:27 PM »
Wow, two early L30/M20 ragtops joining at the same time!
exportcorvette
    • imageevent/exportcorvette
Re: new guy hi
« Reply #6 on: February 08, 2009, 03:31:33 PM »
welcome aboard !
Export Corvette/ Jimmy Hurt
exportcorvette
Re: new guy hi
« Reply #7 on: February 08, 2009, 03:36:32 PM »
welcome aboard !
In addition to the US assembly plants, many hundreds (if not several thousands) of Camaros were assembled by at least four overseas factories: the Yutivo factory in the Philippines (the subject of a CRG research article), GM Continental in Belgium, GM Suisse in Bienne, Switzerland, and a little-known assembly plant in Caracas, Venezuela. The last three factories remain objects of continuing CRG research, and if you have information on any of these facilities, or cars built at them....I have information on 4 1967/68 Camaros with GM FRANCE homogolation/ID plates, indication that GM France modified these cars in the France GM plant. Did GM France assemble CKD pkgs in France ??
PANTHER-BUFF
Re: new guy hi
« Reply #8 on: February 08, 2009, 04:42:26 PM »
Welcome!!!!
Danny
Re: new guy hi
« Reply #9 on: February 14, 2009, 06:58:21 PM »
I'd be interested to see the info, but the VIN's on the French-tagged cars that I've seen indicate they were not assembled in France.
Da67Kid
Re: new guy hi
« Reply #10 on: February 14, 2009, 11:13:47 PM »
Welcome!!! sounds nice
hotrod68
  • almost finished
Re: new guy hi
« Reply #11 on: February 15, 2009, 04:13:28 AM »
Welcome, Flyer!
NED
Re: new guy hi
« Reply #12 on: February 16, 2009, 02:22:57 AM »
Welcome aboard.
Bill
67Z Bench seat
69JL8 Burnish Brown
67 camaro modified ls1,6 speed, 9 "rear
mjbake
Re: new guy hi
« Reply #13 on: February 17, 2009, 09:45:42 PM »
Hold on. Didn't all L30/M20 have the 12 bolt rear end? You both have a 10 bolt? I dont' have any of my books with me to double check.
67 L30/M20
Convertible
Gramps69Z
  • 69 X33 D80
Re: new guy hi
« Reply #14 on: February 17, 2009, 10:11:55 PM »
Check it out on the rear ends being 10 or 12's.
http://www.camaros.org/diffs67.shtml
Captain John Wykoff
