Author Topic: manual steering box  (Read 10088 times)
booya420
manual steering box
« on: May 04, 2008, 05:59:41 PM »
my 67 z came with a manual steering box but is this correct for my car
Re: manual steering box
« Reply #1 on: May 04, 2008, 07:12:32 PM »
Booya -
The casting number (5679142) is correct.  The 305 is the julian date (Tuesday, November 1, 1966) the housing was cast.  This steering box would be correct for your car if the build date of your car is after (within reason) November 1, 1966.  If you clean off the machined pad in your photo (it's between the 7 & 8 O'clock position in your photo) you might find some numbers stamped there that would indicate the date the steering box was assembled.  Check it.  This date too needs to be before your car's build date.
booya420
« Reply #2 on: May 04, 2008, 07:51:05 PM »
thanks a million, a little stress off the mind. i will be sure to check the machined pad tomorow when i get to the shop. another question how do you decode julian dates?
« Reply #3 on: May 04, 2008, 09:04:31 PM »
Go here...   http://www.camaros.org/numbers.shtml#Calendar
tom
    • Discount Internet Services
« Reply #4 on: May 04, 2008, 11:07:49 PM »
Basicaly julian dates cover the year without regard to months. Jan 1 is julian date 001. Dec 31 is julian date 365.
69 X11 Z21 L14 glide
o
Nate Biery
  • 67 base coupe w/ some goodies.
« Reply #5 on: May 05, 2008, 06:52:39 PM »
Hey booya. I assume you are rebuilding/restoring. I have some play in my manual gearbox and was wonder if your gearbox had some "play" in it and could you tell me where you got your rebuild kit from. If you are not rebuilding then do you know if there is some adjustment to tighten things up?
Nate
booya420
« Reply #6 on: May 07, 2008, 02:15:38 AM »
ya i am restoring but i have yet to find a rebuild kit. as for the adjusting, in the photo, where you can see into the steering box, there is a cover over that with 3 bolts and a threaded rod with a slot and a nut. this rod adjust the gears into mesh with each other. and the nut locks it into place. if the rod is already threaded in all the way the gears are worn out and need replacing or repair.
