June 20, 2013, 02:07:41 AM
Search:     Advanced search
83215 Posts in 10596 Topics by 4408 Members
Latest Member: scotthead25
+  CRG Discussion Forum
| |-+  Restoration
| | |-+  1968 motor mount safety cable
« previous next »
Pages: [1] 2  All Print
Author Topic: 1968 motor mount safety cable  (Read 3110 times)
ujay
Newbie
View Profile
« on: January 14, 2008, 12:33:07 PM »
I am restoring a '68; 327/210 auto with A/C. I am looking for information on the installation of the safety cable on the left side motor mount. I removed a cable about 8" long with long bolt/nut through ends and a smaller cable. I originally had a picture of it installed, but have lost it. Any info would be helpful. Thanks.
Logged
roper
Member
View Profile Email
« Reply #1 on: January 14, 2008, 08:58:59 PM »
on my 69 the bracket mounts to exhaust manifold between the no 1 and 3 pistons and there is a pin thru the bracket,  the cable goes thru the pin, around the upper aframe bushing arm and then back to the pin,
Logged
CRG Member
View Profile Email
« Reply #2 on: January 15, 2008, 11:18:18 AM »
Looks like this.
Logged
68rs327conv
Member
View Profile WWW Email
« Reply #3 on: January 15, 2008, 09:50:03 PM »
Link to installation instructions for both sides http://y2camaro.com/ref/stoplift.php
Logged
68 RS Conv 327/210hp, Powerglide Factory AC
ujay
Newbie
View Profile
« Reply #4 on: January 16, 2008, 10:27:28 AM »
Guys,
Thank you for the responses. You sloved the mystery. My engine is missing the bracket on the driver's side and the longer cable goes on the passenger side. Here's a pic of the cables.
Logged
68rs327conv
Member
« Reply #5 on: January 17, 2008, 02:25:53 PM »
The bracket you need is on ebay from Chicago Muscle Car Parts, ask for Ralphhttp://cgi.ebay.com/ebaymotors/1967-68-69-CAMARO-ENGINE-LIFT-STOP-BRACKET-350-327-302_W0QQcmdZViewItemQQcategoryZ34202QQihZ006QQitemZ160151032429QQtcZphoto
Can you measure the length of cable on the passenger side as that is the part I need unless you are willing to sell it
Logged
CRG Coordinator
View Profile Email
« Reply #6 on: January 21, 2008, 10:47:59 AM »
Why not just install the good interlocking engine mounts and skip the cable bandaid thing?? GM did it only as a bandaid fix - it was that or replace all the engine mounts!
Logged
ujay
Newbie
View Profile
« Reply #7 on: January 21, 2008, 02:30:47 PM »
I do agree that a set of good mounts is better than a bandaid fix. However, since I have both cables, I want to install them because they are part of the cars history.
Mike, thanks for the link to the bracket on ebay. One recently sold for under $20, but I'll keep a watch on this one. I'll measure the passenger side cable and post tomorrow.
uj
Logged
ujay
Newbie
View Profile
« Reply #8 on: January 22, 2008, 09:50:02 AM »
Mike,
The passenger side cable is 13 7/8" end to end. The bolt is 1/4" X 4 1/4" and has a lockiing type nut.
uj
Logged
Jerry@CHP
CRG Member
View Profile Email
« Reply #9 on: January 22, 2008, 10:00:46 AM »
Installing the cables on a restored car will get you point deductions at a national Camaro event.  They were never installed at either assembly plant so they are not allowed in stock judging.  Also consider that we've had to repair exhaust manifolds with cable grooves in them from wear.  Those cables are hard on the cast iron manifolds.
Jerry
Logged
68L30
Member
View Profile
« Reply #10 on: January 22, 2008, 12:22:46 PM »
So, If I have a unrestored 68 with the recall cables and the letter from GM stating the recall and service records for the installation, I will be deducted points? Why not just make more cookie cutter restos..... So much for Camaro preservation..... Tongue
Logged
CRG Member
View Profile Email
« Reply #11 on: January 22, 2008, 12:47:23 PM »
Similar logic prevails in NCRS Corvette judging - the judging standard is as the car left the factory, with normal dealer prep, exclusive of any owner or dealer-inspired additions, deletions, or changes. Anything added, deleted, or changed after the car left the factory is outside the judging standard and is subject to a deduction.
No Camaro ever left the factory with the motormount recall kit installed.
Logged
9T4Z
Member
« Reply #12 on: January 22, 2008, 03:18:20 PM »
I like the look with them in place.  I remember seeing a lot of these on cars in the early 70's and it is a bit of nostalgia.  Unfortunate that it gets a deduction IMO.  I will have mine on for local and Canadian Nationals then I guess I will remove them when I come down to Carlisle... sigh
Logged
Gary 9T4Z
69 Pace Car, 70RS,91Z,91RS
68L30
Member
View Profile
« Reply #13 on: January 22, 2008, 07:02:15 PM »
I understand the "as it left the factory"...I just think it's part of the cars history, more so if you can document it. I sure hope there is a deduction for incorrect  motor mounts in a 68.Ever take the cables off and see what happens? You go for one heck of a ride when the throttle sticks wide open! I did this in my 68 when I first put headers on it. From the end of the driveway all the way up the street.....wide open and out of control! I'm all for the junk motor mounts and the saftey cables in a resto.What good is it if you can't open it up a little?
Logged
tom
Hero Member
« Reply #14 on: January 22, 2008, 09:18:47 PM »
Stuck at full throttle is no fun, I agree. Been there on a twisty road with deep ditches on both sides and oncoming traffic when my carb stuck wide open on an old Cutlass. MOST SCARED I've ever been in a car. I turned off the key.
Get the safe mounts, If you like cables on your car, put them on too. It;s your car enjoy it.
Tom
Logged
69 X11 Z21 L14 glide
looking for a 69 export model (KPH) speedo
« previous next »
Jump to:
Page created in 0.092 seconds with 18 queries.
