Author Topic: hidden vin numbers  (Read 8780 times)
black69
    • my_car
hidden vin numbers
« on: December 02, 2007, 01:00:58 PM »
Are there any other numbers hidden other than the 2 on the firewall? There are none in the trunk lip?
Is the vin welded in on the dash?
Black 69L78. 4:10, RS/SS/ZL2, 'black painted tail panel different than body','red hockey stripe w/ v-top exception'
Blue 68Z28. 4:10, Kustom 'tunnel tube' headers, Nickey sold.
Re: hidden vin numbers
« Reply #1 on: December 02, 2007, 04:26:58 PM »
The two hidden VINs on the upper cowl and adjacent to the heater blower opening are the only two on the body. The VIN plate is attached with rosette pop-rivets, not welded.
« Reply #2 on: December 02, 2007, 04:28:20 PM »
Why do you ask???
black69
    • my_car
« Reply #3 on: December 02, 2007, 05:45:31 PM »
I heard there may be something on a subframe or something. I figured I would ask quickly on this board. I just looked friday at a shell of 71 71 blue 4spd X66 car (no engine or trans) and it had the numbers in the front by the heater and the wipers, but I wondered how one could tell if the rear clip of a car was ever replaced. The quarter were replaced at one time. Thought if there was a stamp somewhere (say in the trunk lip area or under the car, that would be nice to confirm it was the real back 1/2 of the original car. That's about it.
NickeyChicago
« Reply #4 on: December 02, 2007, 09:32:46 PM »
Interesting topic. I just had a very knowledgeable Camaro restorer/enthusiast, tell me that there is a hidden/confidential VIN on the rear clip.
I had to tell him that in three decades experience, I had never seen the proof. Of course, no one knows everything, so I was excited to learn something new, as well as have a good way to easily determine a possible rebody.
Needless to say, I went to my shop and looked over several Camaros and found no additional Confidential VINs.
I know that some Mopars have a confidential VIN on the rear clip.
Is this closely guarded info or just miss-information?
« Last Edit: December 02, 2007, 09:36:37 PM by NickeyChicago »
« Reply #5 on: December 02, 2007, 10:51:58 PM »
Stefano,
Misinfo.
I've seen the model #, 12437, stamped on a panel in the trunk. But that's just to tell the plant it went to a Camaro, not a Caprice, etc. It is not a VIN.
« Reply #6 on: December 02, 2007, 10:56:15 PM »
The trunk lip VIN is Mopar.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #7 on: December 03, 2007, 01:21:43 AM »
Although not 1st Gen Camaro, a couple of additional data points that I have observed on GM A Bodies.
1)  I have seen the VIN stamped on the top of the LH rear frame rail (behind the wheel) of a a 67 LeMans.  There was also stamped the word PARRISH which I assumed related to the manufacturer of the frame.  Until the body was lifted off of the frame, these could not be seen.
2)  There is a date code stamped on the side of the LH rear frame rail of my 66 Chevelle.
           3   18   66 with the letters PON stamped above the 3.
           Since these are on the side of the frame rail, they are visible with the body on.
« Last Edit: December 03, 2007, 01:25:17 AM by rich69rs »
Richard Thomas
1969 RS
