Author Topic: Orange stripe on RS vacuum hose  (Read 17237 times)
David K
  • Dr. Longblock
« on: June 12, 2023, 08:38:41 PM »
30 years later and nobody makes the orange striped hose from the headlight switch to the relay. Inline Tube sells color striped hoses, but not orange. I called tech support…”yes we stripe the hoses, no we won’t  make an orange one.”
As I understand, the Legends cars now require the orange stripe. 🧐🧐🤔🤔🤔
169INDY
Re: Orange stripe on RS vacuum hose
« Reply #1 on: June 12, 2023, 10:02:13 PM »
Lloyd has a show and tell on how to perform this stripe change in his build.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
boomer632
« Reply #2 on: June 12, 2023, 10:12:52 PM »
Man Dave you're getting quite finicky as of late.. first unobtanium grab handle now orange hoses. :)
06A X66 711 57 57 L78 M22 BU
David K
  • Dr. Longblock
« Reply #3 on: June 13, 2023, 05:49:41 AM »
Indy…have a Lloyd link?
Boomer, more unobtanium!
Pacecar
« Reply #5 on: June 14, 2023, 02:13:46 PM »
Main original RS headlight vacuum hose was orange. Called out in AIM. Yes it is a judged for item as that is what is called for
David K
  • Dr. Longblock
« Reply #6 on: June 18, 2023, 12:10:17 AM »
Practicing….
David K
  • Dr. Longblock
« Reply #7 on: June 18, 2023, 02:19:42 AM »
Thanks to Cook-do for the link!
mgerg11
« Reply #8 on: June 21, 2023, 02:01:12 AM »
I used a tire ink pen off amazon…turned out good and passed judging at Bloomington Gold.   Tire Ink Paint Pen for Car Tires Permanent and Waterproof Carwash Safe (1 Pen, Orange) https://a.co/d/2yD5bSn
If you zoom in on the pic you can see it.
David K
  • Dr. Longblock
« Reply #9 on: June 25, 2023, 03:46:21 AM »
Used a different pinstripe stencil kit that left no bleeding under, spray painted 3of them with artistic pro paint, and I can live with it. I can’t live with aqua, pink, and pale yellow stripes. Stay tuned.
David K
  • Dr. Longblock
« Reply #10 on: June 26, 2023, 02:39:06 AM »
Much better
« Reply #11 on: June 26, 2023, 02:44:24 AM »
Are those the correct widths on the stripes?  Looks good.
169INDY
« Reply #12 on: June 26, 2023, 03:21:46 AM »
I was at a Show and saw a friends (LOS) Unrestored Z11 Pacer today.
Orig 1969 Hoses
68 Z28 M21 LOS
David K
  • Dr. Longblock
« Reply #13 on: June 26, 2023, 04:39:17 AM »
Cook….thanks…..the width is 1/16th but my original hoses are long gone. I replicated the width from my 1993 reproduction set that’s still on the car. The paint is so good from that set I couldn’t get it off the hose, I just prepped and painted over the red stripe that goes to the headlight switch. The new kit paint rubbed off with my thumb.
Indy-Thank you for he pictures! I vaguely remember seeing the zippered yellow hose at some point forever ago, and am pretty sure replicating that is damn near impossible. It looks to be 1/8” but can’t really tell. At this point I’ve got the process down to a science, and am going to bring some with me to Morgantown for comparison hope to to fine tune the colors and get the correct width. That other hose that’s next to the red hose looks yellow, but should be green. If you could get some better pictures next time I would appreciate it. I also found a thread from last year that you posted some pictures in, and the yellow looks approximately 1/8” wide, so I’ll redo them. The white striped I believe is a a vacuum hose from the intake.
« Last Edit: June 26, 2023, 05:16:35 AM by David K »
Jonesy
  • 1969 Camaro z28
« Reply #14 on: June 26, 2023, 02:52:46 PM »
Paint looks good. I saved my original hoses. I will have to dig them out and see what the striping looks like. I have a VanNuys car 11B.
The 90's repop hoses were not high quality rubber. They would split at every connector. I still have them on my car. Not sure how the new hose kits are
1969 Z28 Azure Turquoise
