Author Topic: Caveat Emptor...block stamp  (Read 1911 times)
« on: May 08, 2023, 01:48:20 PM »
https://www.ebay.com/itm/145071564766
124379L525822
From the ad:
1969 Chevy Camaro REAL DEAL SS350 numbers matching rebuilt 350.
Pic of block stamping shows 19L525822  T0219HC
HC is an L65 350/2 barrel w/manual trans
Was not a Camaro SS.
David K
  • Dr. Longblock
Re: Caveat Emptor...block stamp
« Reply #1 on: May 08, 2023, 03:04:31 PM »
Did someone take a sawz all to the trim tag or is that just a bad picture?
« Reply #2 on: May 08, 2023, 05:22:07 PM »
Not an SS 350, but block looks original for that car. Right?
Tag pic looks like a mess.
« Reply #3 on: May 08, 2023, 07:50:14 PM »
Yup, original 350 HC block.
Tag looks to have been sandblasted.
Petes L48
« Reply #4 on: May 08, 2023, 08:05:03 PM »
In the description he's now claiming it's a faint HG, not HC.  Looks like a clear C to me.   Maybe he'll blur that picture next.
« Reply #5 on: May 08, 2023, 08:14:16 PM »
Quote
It's clearly an HC and to his credit, he's now stated that it's an L65 and not an SS. He still needs to fix the 12 bolt reference since this car probably came with a 10 bolt. And that's not the factory Hurst shifter.
« Last Edit: May 08, 2023, 08:40:20 PM by bertfam »
« Reply #6 on: May 08, 2023, 08:20:40 PM »
Good work guys! Clearly HC and saved here for future reference.
« Reply #7 on: May 08, 2023, 08:29:59 PM »
Yes, the trim tag is beat up, but I'm more curious as to what this is (see arrow)!!
camaronut
« Reply #8 on: May 08, 2023, 08:50:28 PM »
Corvette distributor mechanical tach drive is me guess.
« Reply #9 on: May 08, 2023, 08:53:25 PM »
Quote
No, can't be. The distributor is over a foot away from the trim tag when mounted. And from the pictures, it appears the engine is sitting on an engine stand. Unless the distributor's zip tied to something in the engine compartment??? But my 69 Corvette and 57 Chevy both have the tach drive distributor and neither of them have that (what appears to be) "C" clip next to the cable. It's a threaded union (see attached)
Kelley W King
« Reply #10 on: May 08, 2023, 09:23:17 PM »
some cruise control? just thinking out loud
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #11 on: May 08, 2023, 09:32:25 PM »
Quote
If it is, it has to be aftermarket like maybe from JC Whitney, Sears, Western Auto or Monkey Wards. RPO K30 wasn't available in 1969.
« Reply #12 on: May 08, 2023, 10:03:31 PM »
Hats off to Dean's Hot Rods!
67rs/ss350 68z/28
« Reply #13 on: May 09, 2023, 01:52:32 PM »
Being the transmission is out of the car, I think they took off the speedometer gear housing and left it on the speedometer cable and hung it complete on the wiper motor?
« Reply #14 on: May 09, 2023, 02:24:48 PM »
Quote
I think you're right! Which means that's not a "C" clip but an O-Ring. Good job!!
