Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
Engine Numbers
« previous
next »
Print
Pages: [
1
Author
Topic: Engine Numbers (Read 6944 times)
stovebolt_six
Newbie
Engine Numbers
on:
April 24, 2007, 10:01:25 PM »
Okay fellas, I've found two more engine numbers for you "numbers gurus" to decode if you would and they are as follows:
1) FI228 YS
2) VII23WA
Thanks in advance...Clint
Tweet
Logged
Hero Member
Re: Engine Numbers
Reply #1 on:
April 24, 2007, 10:47:45 PM »
Clint -
Both are truck engines. YS = 1966 or 1968 327 cid engine. WA could be a 283, 307, or 350 cid engine depending on the block casting date. If you know the block casting dates we can narrow it down for you.
Logged
Hero Member
Re: Engine Numbers
Reply #2 on:
April 24, 2007, 10:49:58 PM »
"YS" was used in Chevrolet Trucks from 1965 through 1969 in a few configurations:
1965 - 283/185
1966 - 1967 - 327/220
1968 - 327/240
1969 - 396/310
The "WA" was also used in Chevrolet Trucks from 1965-1969 in the following configurations:
1965 - 1967 - 283/175
1968 - 307/200
1969 - 350/255
You'll need to get the date code to see which engine yours is.
Logged
RAfbody
Member
Re: Engine Numbers
Reply #3 on:
April 25, 2007, 02:50:22 PM »
I would have to think the F1228YS would be the 65 or 66 engine since the assembly plant code is "F" instead of "V". I don't remember the date the flint engine plant changed from F to V but I know it had changed by 1967.
Logged
Russ
CRG Member
Re: Engine Numbers
Reply #4 on:
April 25, 2007, 04:32:30 PM »
The Flint V-8 prefix changed from "F" to "V" at the beginning of the 1967 model year.
Logged
Print
Pages: [
1
« previous
next »
Decoding/Numbers
Engine Numbers
