Author Topic: Preservation of a 68 Camaro  (Read 256076 times)
Re: Preservation of a 68 Camaro
« Reply #270 on: March 27, 2023, 01:19:16 PM »
Photos 552 - 553 - Gas pedal and throttle arm.
« Reply #271 on: March 27, 2023, 01:21:21 PM »
Photos 554 - 555 - Next were the Astro Vent duct work and the bezels & balls
« Reply #272 on: March 27, 2023, 01:23:16 PM »
Photos 556 - 558 - Using my Harbor Freight special da polisher I run over the dash face with some Mequiars 105 since I had previously had #7 soaked into the paint prior.  Note the lack of paint in and around the knob areas.
« Reply #273 on: March 27, 2023, 01:25:06 PM »
Photos 559 - 560 - Installation of the drop down brackets, pedal assembly.
« Reply #274 on: March 27, 2023, 01:25:59 PM »
Photos 561 - 562 - Clutch rod along with its boot.
« Reply #275 on: March 27, 2023, 01:28:01 PM »
Photos 563 - 565 - Dimmer switch, ignition, headlight, wiper and cig lighter switches installed
« Reply #276 on: March 27, 2023, 01:29:06 PM »
Photo 566 - Shot from the outside of firewall. Also installed correct 4 rib washer nozzle hoses.
Complete steering column teardown and go through hopefully in the next couple of weeks.
« Reply #277 on: March 28, 2023, 02:12:30 AM »
Photos 567 - 568 - Close up of the control knobs.
« Reply #278 on: March 28, 2023, 02:14:06 AM »
Photos 569 - 571 - Cluster installed. First time since the late 70’s
169INDY
« Reply #279 on: March 28, 2023, 02:58:10 AM »
Sweet! Great progress.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
« Reply #280 on: March 30, 2023, 12:42:21 PM »
Now that the defrost duct, heater box, controls & radio are now in I touched them up from all the handling.  303 is the product I'm trying on the duct work.
Photos 572 - 575 - Under dash area passenger side compartment.
« Reply #281 on: March 30, 2023, 12:44:05 PM »
Photo 576 - Glove box door after hitting it with Mequiars 105 on a maroon pad on my da polisher.
Photos 577 - 578 - Dash after controls & radio installed.  Also a sneak peak at the trio of gauges I'll be installing into the car as well.
« Reply #282 on: March 31, 2023, 11:58:22 AM »
Photos 579 - 580 - Mounting some accessories.
« Reply #283 on: March 31, 2023, 11:58:57 AM »
Photos 581 - 582 - Cont.
« Reply #284 on: March 31, 2023, 02:58:44 PM »
Great work Darrell and detail to assist others......
