Author Topic: Question on fan and clutch  (Read 3419 times)
Mad4wd
« on: August 28, 2021, 10:42:40 PM »
Got this with some parts, and not sure if it's application. I am working on a 69 Z/28. I can't find a lot about this clutch. If it's not for my car, then can someone please help with application so I can get it to someone who can use it.
Fan #3937779 dated H68
Schwitzer clutch dated 10-6-68 SC, 5/8" pilot, about 1.7" from fan to water pump flanges
Re: Question on fan and clutch
« Reply #1 on: August 28, 2021, 10:49:32 PM »
Did you read THIS? You have a early 1969 Camaro Z28 fan and clutch.
« Reply #2 on: August 28, 2021, 10:59:38 PM »
What's the build date of your car?
Mad4wd
« Reply #3 on: August 28, 2021, 11:05:52 PM »
2-19-69
I did read it...multiple times
I see where it says the fan was early 69
So the SC clutch is definitely DZ302 early 69?
« Reply #4 on: August 29, 2021, 12:18:12 AM »
That's a little early for your car. You should be running the 3947772 fan or the 3956684 fan and the 3946804 (CV) clutch.
« Reply #5 on: August 29, 2021, 12:58:13 AM »
Not for your car. No way to tell what the clutch went in originally without the broadcast code or part number for the fan clutch.
« Last Edit: August 29, 2021, 04:12:10 PM by KurtS »
