Author Topic: Subframe to body, alignment  (Read 10408 times)
69Z28X33
« on: April 10, 2007, 12:30:54 AM »
I'm concerned about how much tolorance I have on the alignment of the subframe to the body.
I want to make sure the front cap assembles correctly. The alignment keeps changing after I torque the bolts.
Larry
Bjv69ss
Re: Subframe to body, alignment
« Reply #1 on: April 10, 2007, 12:34:37 AM »
There are two alignment holes under there.  Use two punches that fit the holes and you should have it.
1969 Fathom Green
SS 350 Coupe
71 Impala Sport Coupe
69Z28X33
« Reply #2 on: April 10, 2007, 01:31:11 AM »
There is about an inch between the upper and lower alignment holes. This
would alow the alignment pin not to be plumb.
x77-69z28
« Reply #3 on: April 10, 2007, 02:37:48 AM »
find a threaded bolt that fits the alignment hole. tighten  a nut attaching it to the chassis.install the chassis and torque it down. remove the alignment bolts.
Bjv69ss
« Reply #4 on: April 10, 2007, 10:43:49 AM »
i used the punches.  they worked fine for me.  If you want to double check your mounting find a same spot left and right side and use a tape measure from a point on the body to the frame and do an "X" measurement.  ?Check it as you tighten.  A same measurementis a squared frame.
Joe
1969 Fathom Green
SS 350 Coupe
HOGDADDY
« Reply #5 on: April 25, 2007, 06:24:12 AM »
Here's is another suggestion get 2 Camaro jack handles they will give ya some leverage.
Ron C.
« Reply #6 on: April 27, 2007, 11:21:29 PM »
is that the same for the 67 also?
« Reply #7 on: April 27, 2007, 11:30:53 PM »
Yes.
