Camaro Research Group Discussion => General Discussion => Topic started by: 69Z28X33 on April 10, 2007, 12:30:54 AM
I'm concerned about how much tolorance I have on the alignment of the subframe to the body.
I want to make sure the front cap assembles correctly. The alignment keeps changing after I torque the bolts.
Larry
There are two alignment holes under there. Use two punches that fit the holes and you should have it.
There is about an inch between the upper and lower alignment holes. This
would alow the alignment pin not to be plumb.
find a threaded bolt that fits the alignment hole. tighten a nut attaching it to the chassis.install the chassis and torque it down. remove the alignment bolts.
i used the punches. they worked fine for me. If you want to double check your mounting find a same spot left and right side and use a tape measure from a point on the body to the frame and do an "X" measurement. ?Check it as you tighten. A same measurementis a squared frame.
Joe
Here's is another suggestion get 2 Camaro jack handles they will give ya some leverage.
is that the same for the 67 also?
Yes.
