Author Topic: Parking Brake Assembly - Flange Nut Finish  (Read 12737 times)
Edgemontvillage
« on: December 18, 2020, 08:51:44 PM »
I'll be re-installing the parking brake assembly on my 69 RS/Z project soon and in preparation was reviewing pre-tear down photos of the (2) flange nuts where they attach the assembly to the firewall, to confirm their finish. I thought the finish was manganese (dark) phosphate, consistent with the flange nuts used to attach the brake booster to the firewall, however from the photo below it appears the finish is instead gold dichromate / gold zinc. Can anyone confirm this?
x66 714
Re: Parking Brake Assembly - Flange Nut Finish
« Reply #1 on: December 18, 2020, 09:56:07 PM »
In Aug of 1969, they were phosphate but not dark. Kind of medium. Just cleaned mine. Almost at that point. Big wad of black goop on the bracket where it goes up to the inside of the firewall...Joe
Edgemontvillage
« Reply #2 on: December 18, 2020, 10:57:22 PM »
Thanks for posting Joe, my Z is a February (Norwood) build so could be different.
« Reply #3 on: December 19, 2020, 02:04:03 AM »
Nut is p/n 1359887.
Also used to secure the hood bumper studs, front console mounting bracket, RS lower actuator bracket. Has several exhaust system applications. Probably furnished in several finishes.
Edgemontvillage
« Reply #4 on: December 19, 2020, 03:49:52 PM »
Nut is p/n 1359887.
Thanks William.
« Reply #5 on: December 20, 2020, 05:59:52 PM »
Nut is p/n 1359887.
William, wouldn’t the part number print dictate finish requirements? That part number application seemed to be phosphate mostly Lloyd but can surely understand the question from the pic supplied.
« Reply #6 on: December 21, 2020, 04:01:34 PM »
In those, days it usually did. Not unusual to see more than one approved finish on an Engineering drawing. There is often more than one supplier; some have in-house capabilities.
Finishes can be difficult to manage. When I worked in automotive supply chain, I had an assembly that consisted of two parts from different suppliers. Each was powder coated in satin black, made it through PPAP. When assembled, they didn't match. Chrome parts can surprise you; don't always match either.
Edgemontvillage
« Reply #7 on: December 21, 2020, 04:16:18 PM »
As so many fasteners on our cars are subject to points judging (Bowtie / Legends) and will attract a deduction if deemed "incorrect" as to finish or plating, I'm looking for feedback if gold dichromate / gold zinc is a typical finish or non-standard for this flange nut. I've not seen this fastener in other than manganese phosphate for the parking brake assembly.
« Reply #8 on: December 21, 2020, 04:36:32 PM »
I have dismantled many '69s in my days and never saw 1359887 in anything other than phosphate. But your car was obviously built that way. I had the twin to your car, about 50 VINs later, and it had phosphate. They should place more emphasis on fasteners being physically correct since plating can vary, even from the same supplier.
Don't get me started on judging. Heard plenty of complaints. No one knows it all.
« Reply #9 on: December 21, 2020, 05:57:00 PM »
There are such varied anti-oxidation coatings/treatments used in the various fasteners on our early Camaros, it makes me wonder if GM had a simple anti-oxidation specification for their fasteners which allowed suppliers some options as to which to use.   Does anyone have any factual information in this regards?   If so, then that would explain why various anti-ox coatings are found on fasteners, even specific fasteners which were procured from multiple suppliers...
« Reply #10 on: December 21, 2020, 10:38:21 PM »
It is typically hours of salt fog/spray. In my experience, Engineering drawings will reference a company spec. The supplier will select a finish that meets the requirements. Very few automotive fasteners will also have an appearance requirement but my stuff did. Chrome and stainless went from 90 hours of spray to around 120. Resulted in some very expensive fasteners that few companies offer.
« Reply #11 on: December 22, 2020, 02:37:31 AM »
Lioyd, here is an example, William noted where that part number fastener is used on hood bumper studs. I tend to believe those fasteners are phosphate and not the black looking manganese phosphate. I have that on our 68 and it received no demerits in 5000 point legend judging but either could be considered ok. Your point is well directed as the couple places where mine was somewhat different in fastener use and kept what I found, it got dinged. Lol
x66 714
« Reply #12 on: December 22, 2020, 03:00:48 AM »
Mine cleaned up perfectly. No refinishing required. I will see if I can take a good picture....Joe
« Reply #13 on: December 22, 2020, 04:06:47 AM »
   Regarding the phosphate hardware, was the salt spray test done with our without the oil bath applied? One of the advantages of using a low cost phosphate application is the surface made an excellent base for an oil preservative.
« Reply #14 on: December 22, 2020, 04:13:35 AM »
I've looked at my original prints. They normally call out a plating, but often have an optional. Prints do not call out a corrosion spec - that's the job of the engineer, not the supplier.
