Author Topic: Parking Brake Assembly - Flange Nut Finish  (Read 6429 times)
Edgemontvillage
Re: Parking Brake Assembly - Flange Nut Finish
« Reply #15 on: December 22, 2020, 06:33:15 PM »
Quote
Lloyd, here is an example, William noted where that part number fastener is used on hood bumper studs. I tend to believe those fasteners are phosphate and not the black looking manganese phosphate. I have that on our 68 and it received no demerits in 5000 point legend judging but either could be considered ok. Your point is well directed as the couple places where mine was somewhat different in fastener use and kept what I found, it got dinged. Lol
Thanks for your thoughts on the subject Chick, I assume you mean zinc phosphate rather than manganese. Of interest, some of the fasteners I've restored including these in manganese phosphate come out closer to medium gray resembling zinc rather than manganese. Must be the alloy that is influencing the finish color. There have been a few small exceptions I've made in the process of my restoration where I've observed an original part that I'm convinced was factory installed such as these flange bolts, however when the finish or part isn't typical or normative I'm inclined to restore it to the accepted standard to avoid a challenge or deduction. Better safe.
« Reply #16 on: December 28, 2020, 03:33:55 AM »
Quote
Lloyd, I use two, the one dark manganese (very dark in color) and other is called gray phosphate which gives me that nice gray appearance found on many including what we are discussing. Do agree material and amount of time left in bath helps dictate the color.
Edgemontvillage
« Reply #17 on: December 28, 2020, 04:29:17 PM »
I was referencing the Palmetto brand whose phosphating solutions I use. They refer to their solutions as zinc (light-medium gray) and manganese (dark gray-charcoal) to distinguish them by gray scale. If you use a different brand they would likely use different names however to my knowledge there are only two types available.
« Reply #18 on: December 28, 2020, 08:54:31 PM »
Lol yes that is what I use, And was just calling it gray phosphate.
« Reply #19 on: December 28, 2020, 09:29:15 PM »
^^^ That is the Good stuff!
« Reply #20 on: December 29, 2020, 03:20:33 AM »
How fast do you use the solution? Would a pint last for a bunch of fasteners or is a quart a better amount?
« Reply #21 on: December 29, 2020, 03:40:32 AM »
I bought a quart of their light gray solution several years ago.  I've done at least 2 or 3 large batches of fasteners during that time and I still have nearly a half quart left.
Edgemontvillage
« Reply #22 on: December 29, 2020, 06:42:23 AM »
Kurt, if you follow directions closely ensuring parts are well prepped, very clean and oil free, and don't allow the solution to overheat (boiling is the kiss of death) a few uses (heat cycles) are possible before the solution is depleted so you can get plenty (many hundreds) of fasteners treated with a quart of concentrate. I've found the solution's shelf life is about 18-24 months before it breaks down (solids appear) and it loses effectiveness. Others' experience likely varies.
« Reply #23 on: December 29, 2020, 12:04:55 PM »
Lloyd hit the mark well Kurt and I was able to do all my original 68 screws, bolts and nuts with a quart of each and had some left over. You mix solution with distilled water and it can be used several times. I use a hot plate as it naturally keeps solution in the 180 to 200 degree desired range. Keys are glass beading parts just prior to phosphate process and then cleaning off after phosphate bath. Palmetto advises using WD-40 but I found dipping parts in mystery oil and lightly brushing with soft brush worked well. Search and several good threads have discussed process in detail.
« Reply #24 on: December 29, 2020, 01:44:22 PM »
I haven't seen any 'solids appearing' or breakdown in the phosphate solution when still unused in the original bottle (probably 7 or 8 yrs since purchased).
I don't recall the dilution % specified off hand, but you add a certain amount to a larger amount of hot water (200 F) to use it.   Only rarely have I needed to 'reheat' an already used solution for later use, so I suppose when Lloyd talks about 'breakdown' that's what he's referring to.   I only mix up what I need for the prepared parts I have and after treating them I generally dispose of the used solution.
I have a gallon of WD 40 that I use to clean/seal the phosphate after phosphating; I do reuse the WD 40 bath I use, replenishing when necessary.
PS.  I purchased a 'set' of stainless steel 'pots' from Walmart fairly inexpensively, so I use the 'best' size pot for the amount of parts I'm doing.  I also use an inexpensive 1 burner hot plate for heating the water/solution.
