Author Topic: Hard to start after sitting  (Read 4937 times)
Chuck69Z
« on: June 29, 2020, 09:57:37 AM »
 Engine used to start after sitting a few weeks with normal cranking time. Yesterday would not fire, finally put a little gas down the carb and fired up. Ran the car down the road and let it sit for a few hours and started up normal. Is this a gasket problem or carb?
red69
Re: Hard to start after sitting
« Reply #1 on: June 29, 2020, 01:49:00 PM »
I'd check fuel pump first.
« Reply #2 on: June 30, 2020, 01:13:11 AM »
If they haven't been started in a week. I pull the aircleaner lid and fill my Holley fuel bowls through the vent tubes - the Quadrajets only get a splash of fuel down the throttle bores. Both then fire off as soon as they turn over.
FWIW The later Holley equipped LT1's 71 - 72have phenolic spacers to take up volume in the fuel bowl in -order to lower the amount of fuel which evaporates to the atmosphere, thereby reducing emissions.
Here is a photo of one I picked up for my LT1.
Chuck69Z
« Reply #3 on: June 30, 2020, 09:54:25 AM »
Thanks guys. I plan on working  over the 4th of July. Ill try fuel pump first and go from there.
