Author Topic: Cowl induction air cleaner base tube  (Read 5016 times)
jvb6648
  • 716-796-5263
« on: March 30, 2020, 07:05:09 PM »
Does anyone know if the tube for the right valve cover on the base of the cowl induction air cleaner is available anywhere? It's for a Z/28, not shown as a separate part in the AIM.
68 Z/28
Re: Cowl induction air cleaner base tube
« Reply #1 on: March 30, 2020, 07:49:42 PM »
It's part of the base, crimped or tack welded in place. Not the same as the rocker cover tube which is 3/4". Early production tubes were 90º which will not clear a double-pumper carb. 2nd design had 2 45º bends.
Some of the older service replacement open element air cleaners included a bag of different vent tubes to cover a range of applications.
Jerry@CHP
« Reply #2 on: March 30, 2020, 08:49:46 PM »
Only thing you can do is find an original open element base and rob the arrester tube off of that.  It's basically the same and can be tack welded in place.  Length may be slightly different.
Jerry
« Reply #3 on: March 30, 2020, 09:25:12 PM »
Jerry
...and I know where a damaged open element base is located.
jvb6648
  • 716-796-5263
« Reply #4 on: March 30, 2020, 11:43:45 PM »
That's probably what I'll do. Thanks for the help
68 Z/28
rszmjt
« Reply #5 on: March 31, 2020, 03:33:25 PM »
Corvette Central sells them - #153004
I don’t know if they are exactly the same but I’ve used them before and they work out fine, some mocking up before I plug tig welded it back into the base.
« Last Edit: March 31, 2020, 04:20:48 PM by rszmjt »
jvb6648
  • 716-796-5263
« Reply #6 on: April 01, 2020, 03:47:57 PM »
Thanks Mike, in stock but running low.
68 Z/28
rszmjt
« Reply #7 on: April 01, 2020, 04:40:33 PM »
Your welcome Jim.
